Question about Bosch 30 in. NGP 732 / 736 Gas Cooktop
Electronic Igniter for Gas Stove
My problem is that the GFI clicked off,,,and finally detemined it was due to the electronic igniter,,,, as when I unplugged it from its own receptacle under the casbinet... I was able to reset the GFI,,,
Now if I simply plug in the igniter,,,it trips the GFI... without even attempting to use the igniter..
So... whst might I try now....
Charlie
    President:
  • 1,314 Answers
Remove the gfi and use a non gfi outlet
Posted on May 16, 2008
  • 145 Answers
Try another outlet first. The ignitor runs off a grounded circut that could be messing with the GFI. I have had manufactures reccommed not using GFI's with relite ignitor systems.
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
Ignitors clicking
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
How do we get the electric igniter to go off?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 02, 2010 | Whirlpool GLT3034 Gas Cooktop
Spark ignitors went on stove top
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Bosch 30 in. NGP 732 / 736 Gas Cooktop Logo
437 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
