Question about General Electric Dinamap ProCare Series Vital Signs Monitors - Pro 300
We have a Dinamap and are getting an e13 while plugged into the wall
3 Suggested Answers
fjmurdock
  • 83 Answers
SOURCE: Dinamap ProCare 300 error 'E13' displayed.
E13 indicates the battery is too low. The reason this occurs when you press 'inflate" is due to the battery being low and the inflation pump requiring more power to start the process. Make sure your green charge light is illuminated when plugged into AC (most likely it isn't). Check your power connections first: power cord to brick connection and barrel connector to Dinamap connection. If you pressed those in and still no charge light, replace the power cord, if still unsuccessful you'll have to buy a new power brick.
Posted on Dec 31, 2010
fjmurdock
  • 83 Answers
SOURCE: My dinamap is giving me E13 msg. and I have tried
E13 indicates not enough battery power. Does this error come on when plugged into AC? If so, please check the front of the unit to see if the green charging light is on (seen under mmHG), I bet you it's not illuminated. Check your power cord to power brick connection and the barrell connector to Dinamap connection (one of them is probably loose). If they are seated fine yet no indicator is lit, replace the power cord and if that doesn't solve it then order a new power brick.
My dinamap is showing error 950 when i hit the inflate start button. what is wrong?
HI From a Tech Guy,
Your issue is caused by motor over current.
Check the pump motor assembly under the foam cover.
remove torx screw on top.remove cover that has two nipples.
check inside mesh filter/ dust filter. if black is dust.
spray contact cleaner and blow with air. let dry.becareful not to use slovents may damage blue mushroom check valve.reassemble all.test should be ok.
hope it helps
cheers
Mar 12, 2012 | General Electric Dinamap ProCare Series...
There is a discripincy between dynamap temperature and thermometer readings. Is there an expected % difference between dynampa readings and thermomters?
Hello dear
Thermometer reading is more accurate then dinamap reading.
In dinamap take three reading and then the average of these three are the correct one, But in thermometer the first reading is accurate.
Well in dinamap it shows usually plus minus 5 difference.
Hope the answer will help, do rate it please
Regards
Feb 28, 2011 | Health & Beauty
I get an Error E13, I think it's due to my battery being low and not recharging
Yes, it's the battery not being charged or the battery itself.
When it is plugged into AC, do you see the word "charge" lit up on the face of the unit in green (you have to get level with the face of the unit to make sure of whether or not it's lit)? If it's not lit, check the right hand side of the unit to ensure the plug in inserted completely. Next check the AC cord to electrical brick connection, it may look like it's all the way in but trust me there's some play in this area, push it in. If it still isn't lit at this point, have someone look at the face of the unit to see if the charge indicator turns lights when you wiggle the power cord near the plug that goes into the AC socket - if it flickers during movement then you have a bad power plug.
If it has charged for 24 hours and you're still getting E13, take it off the pole, remove the pole mounting bracket underneath and remove the bottom case assembly- you should see the battery now.
Feb 10, 2011 | General Electric Dinamap ProCare Series...
My dinamap is giving me E13 msg. and I have tried replacing cuff, hose and checked all connecters. I have 3 units so have tried the same connectors and hose with cuff on another unit and it works fine....
Oct 21, 2010 | General Electric Dinamap ProCare Series...
We have a load in the washer. the message E13
unplug it for a min plug it back in hit drian spin start unit. needs more info model brand
Jun 02, 2010 | Washing Machines
I have a Dinamap Pro 1000. In a recent urgent
Vaguely remember that unit(or something similar--Dinamap Pro 1000)back when before I retired from my clinical nursing position in 2013. Seem to recall it had a SMPS(switching-mode power supply) that had a coaxial power plug which plugged into the unit itself to provide power to the monitor and also seem to recall that the monitor had various functions/inputs for things like BP, HR, Thermometer, and pulse-oximetry. Anyway that SMPS, like several others I've dealt with over the past 15-20 years, was in some sort of generic "black-box" type of enclosure which had a standard 120 Volt AC cord feeding in one side and the DC power cord going to the monitor coming out the other end. Anyway I'll probably need to see if I can pull up a parts list and/or schematic or product specs for that particular model. I've been an amateur electronics enthusiast/hobbyist for something like 30 years--in addition to 40+ years as a health-care professional. But would suspect that the coaxial power plug; if that's what you replaced; might not have been the proper type, wasn't correctly soldered, or the polarity might've been switched when you replaced it. Alternatively the SMPS might've suffered sufficiently severe of a "short" so as to overload the normal over-current protections that such devices have as inherent protection. Anyway will see if I can pull up any relevant data. And please don't try to use the device on any human until it's fully functional.
Mar 17, 2017 | General Electric Dinamap ProCare Series...
Adjust time on a procare 400 dinamap
GE Procare 400 DPC-420N Unit turned off. Hold down Menu button while pressing the On button. Press Menu button several times until see a display to the left of the ?min? on the display area. Use + and ? to set time.
Feb 24, 2010 | General Electric Dinamap ProCare Series...
E13 and clothes are trapped
try setting the knob to the stop position, turn off the power and pull out the plug and wait for 2 mins and it should open.
Sep 18, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Apr 07, 2009 | General Electric Dinamap ProCare Series...
General Electric Dinamap ProCare Series Vital Signs Monitors - Pro 300 Logo
93 people viewed this question
Top General Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a General Electric Health and Beauty Expert? Answer questions, earn points and help others
