FixYa.com
Tags:
Refrigerators
Generic problem for all Refrigerators
Counter depth refrigerator
posted by Rhonda285 on May 16, 2008
My counter depth refrigerator hits the corner of the countertop when the door swings all the way open, marking up the stainless steel door. Do you have any suggestions for preventing this? Maybe a creative way to stop the door from opening all the way? I thought about putting something on the edge of the countertop, but even rubber could cause denting.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 16, 2008
Not Rated (0)
Cyril J
Rank:Wiz Wiz
Rating: 79%, 16 votes
just to make sure , it is when the door is open to 180 degrees?
the door should have a door stop on it under the hinge.
is screws to the door then hits the hinge when it gets to about 160-170 degrees stopping from opening more
somtimes if a door is replaced this part is left off or yours maybe damaged
give me a model number i can tell you more
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
BNewberry
Rank:Wiz Wiz
Rating: 87%, 15 votes
Do you have room to pull the fridge out from the wall, maybe just a couple inches? Pulling it out from the wall should give you more door swing without hitting the counter.
Let me know if this works for you.
Thanks,
Bill
This Problem Also Relates To: GE 21.7 Cu. Ft. Top-Mount Refrigerator with Internal Water Dispenser - Stainless-Steel GE GSS25SGMBS Side by Side Refrigerator GE GTS22KBP Top Freezer Refrigerator GE (GTS16BBS) Top Freezer Refrigerator GE PDS22SBRLSS Bottom Freezer Refrigerator GE PFS22SISSS Stainless Steel French Door Refrigerator GE Profile? GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
Can you Help with these Refrigerators problems?
Kenmore 50522 / 50524 Side by Side...
kenmore model #106 55522400
ice maker is making ice but not... Answer This...
Refrigerators
GE pss26mg Profile
How do you change a water line... Answer This...
Refrigerators
water is pooling in the
water is pooling in the bottom... Answer This...
Whirlpool GS6NBEXR Side by Side Refrigerator
refrigerator ice machine
Our brand new whirlpool... Answer This...
Nor-Lake Norlake Refrigeration 4' x 6' Kold...
Maytag refrigerator model #...
Water is pooling daily on the... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
