Question about Kenmore 42822 Front Load Washer
The washer will stop 2 minutes before the end of the cycle and beep continuesly without draining or spinning the clothes!
  • 2,272 Answers
If the washer will fill but won't drain and spin then the motor control is most likely at fault.It will require a live voltage check at the motor control to determine what the problem is.Do you hear the motor running with beeping noise.Also any front panel light flashing with beeping or only beeping is noticed.Does it beeps non stop or pauses after some beeps and continue again beeping. You did not indicate if any lights are flashing along with the beeping. Generally speaking whenever the control is beeping continuously the five vertical lights above the Pause/Cancel button will flash and the START indicator will flash. The flashing lights above the Pause/Cancel button and the flashing START light are indicating an error code. To check what error code your washing machine is indicating.Please click on the link below:--- http://media.fotki.com/1_p,sswqqssgkqktgffxgtqsskgwtqkq,vi/wwqwgqffbxwddfqwkfbxfksqrdkbk/1/1303472/5961857/image1692746404187201893img-or.jpg ----------- Click this link for reaming test procedure:--- http://media.fotki.com/1_p,sswqqstdkwqdkbtxgtqsskgwtqkq,vi/bqsrggswkxsdswtrwfwxsbbsgkqrg/1/1303472/5961857/image6948068420903353406img-or.jpg ----------------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 14, 2010
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
LG Washer WD 80490TP, At Spin Cycle not Spinning, seems to,start and then stop takes about a half hour to count down the 8 minutes of cycle, without spinning the clothes. Clothes are still wet
Pull the bottom panel off (if don't have access to the drain pump) and open the pump. I'll bet it's clogged.
Washers won't spin if they can't get all the water out...hope this helps.
Apr 02, 2011 | LG Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Kenmore 42822 Front Load Washer Logo
169 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
