Question about Frigidaire Dishwashers
Have a frigidaire dishwasher (model- PLD4375RFC0)about 2 years old. Set to run as we left to go out of town- when we came back all lights flashing including error- found a child's plastic bowl that had fallen to the bottom and had a melted spot as it was next to the heating element. Called support and were told to master restart- shut the power off for 15 minutes. Did and now flashing "27". Cannot find a code for that and neither could support without sending out a repairman. Any advice before we pay for a service call?
  • Frigidaire Master
  • 3,182 Answers
Google the make and error code they is a online forum which you ask about your code found nothing else on code 27
Posted on May 13, 2017
2 Suggested Answers
  • 5911 Answers
SOURCE: A child's plastic cup top melted on heating element. . .how to remove residue
Gently scrape with a razor blade or paint scraper to remove the large pieces, then use some emery paper or very fine sand paper to remove the rest. Use care when applying any pressure on the element, and try not to leave any gouges in the element surface. I have also had good luck with a nail file. Hope this helps you.
Posted on Feb 02, 2008
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Model gu1200xtlq dishwasher can't find my manual it is 8 years old and having problems with dishes not getting clean particles left inside cups and on dishes and even inside the tub after a cycle
you can go to and input your model number in the manuels colum and you will be able to download a new manuel.
to clean you dishwasher you can use some CLR or any other kind of lime and scale remover to clean the inside and the spray arms.
if this does no good then you may need to replace the main wash motor.make sure there is enough water in the unit when it is running lack of water is a big problem with not getting dishes clean
Jul 05, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire Aquasurge, panel is flashing, cannot
You might remove the front panel (screws on the sides) pop off the front plate, and remove the fuse. Put it back in after 5 minutes... sometime this fixes it
May 13, 2010 | Dishwashers
Dishwasher won't go through cycle
Model number would help alot!
to locate...Open your Frigidaire dishwasher's door and check the inner frame -- left top corner and the left and right sides --for the product label containing the model number.
or Check the inside of the door frame if you don't find the number on the inner frame.
let us know. thanks!
Dec 27, 2017 | Frigidaire 24 in. FDB635RF Built-in...
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
Jan 02, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
89 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
