Question about Jeep Radios: Genuine 6 Disc Cd Changer
Sony Marine Radio
Installed Sony Marine radio/cd player in my boat and it seems to randomly power down when I turn up volume and sort of reset. Is this some kind of safety feature. Been a while since I installed anything like this my self.
  • Anonymous Jun 11, 2008
    What I found was the locking mechanism was not holding tight enough when the face cover was closed. This caused intermittent operation, I cured it by taping a thin pad on the cover so the prong would make full contact. My only concern is that the seal may not be water tight.
  • Anonymous Nov 13, 2008
    My Sony marine radio will cut off when I increase the volume to around 22 or 23 on the volume dial. When I lower the volume it comes back on What could the problem be.
I have a new Sony Marine radio and they keep getting blown up and I don't know why. Some say it's due to my GPS antenna being so close to the radio, while others say it's due to to much voltage (which is 14.5- 14.8). The fuse on the back has never been blown but the unit comes up stating OFFSET. The manual states that this is a internal problem but what's causing it??
I'd like to know before getting a new radio, I've gone through two units so far.
Posted on Jul 08, 2008
    Sergeant:
    Champion:
  • 359 Answers
Check the wiring is installed correctly make sure you have a good earth & if it is a detachable face make sure the face is on correctly after trying this hold reset button for 15secs
Posted on May 26, 2008
Gentlemen: I have a vintage 1997 Raytheon marine VHF radio on my 1997 Pursuit, not sure of model number as boat is in storage, but it is pretty basic, along with a full slate of Raytheon electronics of...
Hi Jim
Your VHF lives in a fairly harsh marine environment and you're correct in thinking "tuner cleaner" might be the answer. I believe that your volume control is simply dirty. I would suggest using silicone spray (WARNING- Use ONLY the safe for plastics type.) to clean it. I've had good success just removing the control knob and blasting the pot, working it back and forth. You MIGHT wish to do this with the power off however, unless you have a great set of earplugs.
You mentioned that you have a handheld VHFas well. Any chandlery will carry an adapter (about $10) to let you hook your portable to the big antenna should a problem with your marine VHF arise. We've had the occasion once to have to do this and we were glad we carry the handheld aboard at all times.
Cheers!
Apr 12, 2011 | Raymarine Ray218 Marine Vhf Radio E43032
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
High Battery alarm goes off while boat motor is running
power supply for the radio taken from a source wire that is affecting the voltage regulation
take it in or have a radio technician come and check the installation
Jan 09, 2018 | Uniden Solara DSC VHF Marine Radio
Speakers Crack at mid to high volume (anything over level 20)
make sure speakers are connected properly to individual speaker outputs from radio .Also make sure speaker cables going to speakers are not pinched or shorted anywhere
Jul 30, 2009 | Jensen CD400M CD Player
Radio isn't as loud as it should be.
I rekon yer radio is stuffed if ya don't git a new one you'll have to leave the trim tab on when using the radio.
Nov 16, 2017 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
JBL MR-4 CD doesn't eject
The unit probably doesn't think there is a CD inside. Possible doing a soft reset will fix this. Do so by powering the unit and putting a ball point or other pointed object into the reset button opening either on the face of the radio or behind the face. A hard reset can be done by disconnecting constant power from the unit for approximately 15 seconds.
If either of these methods fail, then your unit has a bad CD mechanism or more than 1 CD inside the player. In that case, the unit will have to be serviced by an electronics repair or a local stereo shop. This is a Marine radio, and if installed on a boat, this problem is not too uncommon. Moist air can cause damage to the unit as well as the bouncing on the water that boats do.
Aug 11, 2008 | JBL - MR4W Am/Fm with CD Player White
Sony CDX CA720X in my boat
Mac, I had the same problem, it was the hard wired remote at the Stern. When I unplugged it from the radio, everything came back to life and the radio and CD player are working fine. I'll have to replace the other remote at some point.
Hope this works for you...
Brian
Jul 16, 2008 | Sony CDX-CA720X CD Player
Car Audio & Video Logo
1,186 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
