KP57WS520 5 Blinks
My tv is on standy and blinks 5 times, i have sound but no picture.
  • 8,617 Answers
5 blinks indicates a white balnce failure. Which is usually related to 3 possible causes. they are the following.
1. video output is faulty on one of the CRT PCB check IC9101 on the red, IC9201 on gree and IC9301 on the blue PCB
2. CRT drive IC452 is defective on the A board
3. Screen G2 is improperly adjusted
Posted on May 16, 2008
Sony trinitron tv
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 24, 2013 | Televison & Video
32 inch emerson lcd tv standy light is on power light flashes
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 11, 2013 | Televison & Video
My standy light keeps flashing and every so often it sounds like its gonna come on then it dont
There's no Picture coming out from the screen???even dark-fluctuating picture???
Does it blink?how many blinks interval?
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Apr 29, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have the sony trintron wega 32 hs 500
Seven blinks indicates a high voltage shutdown which has exceeded 33,000 volts and immediately sends the unit into a safety shutdown. In this case you would need to check the power supply regulation circuit and horizontal circuit for the failure. It could be as simple as the horizontal output transistor having failed to something more complex or expensive. Need to have it diagnosed for that to find out.
Bill
Apr 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
Electro Med Services...
