Question about Canon ZR85 Mini DV Digital Camcorder
I get grey lines in the viewfinder when I play back a tape. Any ideas?
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 14, 2010
Why doi have grey lines across my Sharp camcorder VL z7 when It on play back. Theres sound breakage as well. Can someone tell me why?
Do you get the grey line when you play back incamera ?
Have you transferred the file outside the camcorder ?
If you get the grey line in both, invariably the recording head needs cleaning.
Power on the ViewCam.
Eject the tape.
Use a soft lint free cloth and generally clean the head.
The head of the large metallic cylindrical thing placed slightly titled.
It is right at the bottom of the camera beyond those small posts.
If your finger cannot approach, use a swab with mild spirit/alcohol.
Let it dry a minute and then record a fresh material and try.
Please reply if it helped or not.
May 02, 2014 | Sharp Viewcam VL-Z7U Mini DV Digital...
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Grey Lines across video display
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
Sep 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Lines on tape when played back or maybe they are only on viewfind
most likely head problem, try to clean with special tape.If still lines appeared on screen ,head must be replaced.
Dec 13, 2008 | Panasonic AG-DVX100B DV Digital Camcorder
Canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
View finder and LCD both show grey
That think must got damaged... dont woory.. try to clean the head and dont try to put the old tapes in it. it could damage the head. can u see any thing on screen while on recording mode? if yes the problem will be withthe head. use a head cleaner.
Aug 10, 2006 | JVC Cybercam GR-D70 Mini DV Digital...
Canon ZR85 Mini DV Digital Camcorder Logo
54 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
