Question about Cobra 25 LTD 40-Channels Base CB Radio
I have a 25gtl cb without a fuse what size fuse does it run?
    Guru:
  • 773 Answers
They come with a 3 amp fuse. I usually change it to a 4 or a 5 amp fuse.
Posted on Oct 07, 2010
I just put a new alternator on my 97 isuzu rodeo but it still draining the battery and stalling how do I reset the computer so it picks up the new alternator of is it something else
i bet you skipped step 1, in the book, FSM and all car repair books in print, 100 years now.
disconnect the battery neg lug first.!
oops, you blew the main fuses. (or blew up the new alt... sad huh)
cb 7 or cb3 fuses blown? CB means cab fuse.(dash box)
drains driving, i bet.
right.?
and the battery is not 13.3v to 15vdc running (good range)
bet 2:
and engine RPM is 800RPM or more at all times, right?
not 400.
the belt is not slipping or missing.
the connections are all tight
the battery cable lugs, are all clean, x4 ends. right?
no engine stated, size and number of cylinders.
as you may not know, diffr, engines sometimes have diffr ALT.
usa answer (for just 2 engines only , usa)
2.6L and 3.2 liter both have PCM generator gain control pin
and the PCM can be bad.
is the charge light glowing running, ?????
here is the proof the PCM does run the reg inside ALT.
called gen gain line.
25782645-zy5i2xuw3mfjw4tca3plar50-1-0.jpg you didnt blow EB17 main fuse that kills all .
there is the CB fuse , for alt.
Jul 13, 2015 | Isuzu Cars & Trucks
Connex 4600 turbo need too know what size power supply I need too run this as a base
sizing a power supply is simple.....look at the fuse in the radio, and add about 40-50% to it, and look for that size psu
Feb 15, 2014 | Radio Communications
Galaxy Pluto - what size fuse do i need for the DC inline fuse holder?
Most of the CB radios I have worked with used a 1 amp inline fuse as a general rule
May 11, 2013 | Galaxy Radios DX-93T Base CB Radio
Maxon wire fuses
If a inline fuse in a holder the old one will aside from length have the amperage printed on it---very few mobile radios use larger than a 3 amp fuse-----look on metal ends of old fuse if have it for markings like 3ag 3 250---3AG is size, 3 is 3 amp, 250 is max working voltage (120 is fine).
Oct 24, 2012 | Maxon MCB-30 40-Channels Base CB Radio
Size fuse for cobra 25 ltd wx
hi please insert a 6amp fuse on the dc positive line it will work fine with this
Nov 04, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
What size fuse goes in the power supply cord
Hi!
A 5 amp fuse would be perfect for your radio in-line power supply cord.
Hope this helps.
Jun 10, 2011 | Cobra 29 LTD CB Radio
What size fuse do i need on the positive side do i need if i have it hooked to the battery. my cb is a maxon mcb-40. if u cud tell me what size inline fuse i need it would help alot thank you
Most un-modified CB radios run about 2 to 4 amps on transmit. A 5 amp fuse is sufficient for most radios. Check you owners manual for the correct size fuse to use.
Feb 28, 2011 | Maxon Radio Communications
Radio loses signal strength when truck battery on or mike keyed.
Wire your radio directly to battery!
Run about 12 guage stranded wire to your battery with a Blade fuse standard size with a 25 amp fuse sice your using a CB Amplifier inbetween put a 30 amp auto relay.going through the switching contacts.
Now wire a grond to 1 side of relay coil the other use a12v source from fuse box so when key is turned on the radio will come on! If you want cb to come on anytime then I suggest skip relay and rub wires to
the floor with insulated banna connectors but put that fuse in line also the fuses on your cb and amplifier to.
Your problem is your trying to gather DC for your radio off a vecical power source them wires are to thin and you may be getting a Bad ground saight t the battery only best way! If your radio gets weak check your battery if you hve a cb amplifier on turn off durring transmissions without car running! goood luck
May 11, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Fuse size
I believe it's 2.5 amp,but you could get away with a 3-5 amp.
Jan 26, 2009 | Cobra 150 GTL DX Base CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
43 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
