Is there batterys in the cps cc700 there is a cord on it but does the scale part run on batterys
I have lost the power adopter for my Casio cps 700. What is type and where I can buy in Melbourne Australia
https://www.ebay.com.au/itm/AC-Adapter-for-Casio-CPS-700-Digital-Piano-keyboard-Power-Supply-Cord-Cable-PSU/152648348355?hash=item238a8cf2c3:g:IgsAAOSwZ4dZLkFc
Mar 16, 2018 | Casio Computers & Internet
I have a silvercrest kitchenscale (2009 - z25830) always worked properly but now shows the sign out2 when I press on/tare. New batteries are in. I have 4 buttoms on it 1. temperature 2. timer 3. on/tare 4....
I have the same problem, came onto this website, but I guess our scale is broken , because I haven't got any weight on the scale when I put it on.
http://www.lidl-service.com/cps/rde/SID-EE4901A4-2520664B/lsp/hs.xsl/product.html?id=8346817&rdeLocaleAttr=nl&title=Digitale%20keukenweegschaal
Aug 13, 2013 | Hardware & Accessories
Changed the CPS on my 01 330i and still getting same code, car still acting strange. Any suggestions??
This could come from a variety of places... in no particular order... the "new" CPS is bad (get another one)... The battery is weak or has low voltage (replace battery)... The DME may need an update / DIS CD 30.0 or higher... dealer or good Independent shop can do this) last one to look at is the fuel filter (replace)
Jul 26, 2017 | 2001 BMW 3 Series
Instruction manual for a triner postal scale
My scales will not come. I have tried different outlet still nothing. Checked voltage on cord this is good.
Jan 27, 2012 | Health & Beauty
Hello: my digital food scale (taylor digital biggest loser brand) goes on but it does not weigh anything. its stays at zero. i've had it a year but only used it once or twice, so its almost never been...
Hello, Maclay55 -
I hope you checked the owner's manual first, the troubleshooting / problem solving section.
It wouldn't hurt to put new batteries in the scale (2 AAA batteries).
Note: From the instructions for the scales:
6. Do not store scale where you store cleaning chemicals. The vapors from some household products may affect the electronic components of your scale. Do not store scale on its side.
7. This scale is an extremely sensitive weighing device. In order to prevent run down of the battery, do not store anything on the scale.
8. Do not dispose of batteries in fire. Batteries may explode or leak. Do not mix old and new batteries. Do not mix Alkaline, carbon-zinc (standard) or Nickel-Cadmium (rechargeable) batteries. Remove the batteries if the scale will not be used for a long period of time.
Source:
1037BL The Biggest Loser by Taylor Stainless Steel Platform Scale Instruction Manual, pages 4-5
http://taylor-enviro.com/media/IBs/1037BL_ib.pdf
If installing fresh batteries does not work, then I suggest you call the Taylor USA Consumer Help & Support department. This is the link to the web page with the US and Canadian telephone numbers:
http://taylor-enviro.com/taylor-support/
Best wishes.
Feb 11, 2018 | Taylor Precision Products Taylor Precision...
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Fuel filter changed of Saturn Vue 2002
Never allow Saturn touch a Saturn.
During the oil change, the Saturn dealer loosened the center positive electrical battery cable at the main fuse box, drivers side, under hood.
The loose positive cable results in an electrical surge that wipes out the cps.
The new cps is only avaqilable from Saturn.
When the new cps is delivered, one electrical pen will be bend down and must be straightened prior to insertion of male and female electrical connector to the cps. Otherwise the new cps will fail.
Be certain to tighten the center positive post of three that secure the main fuse box in place. The center post must be tightened to ensure the new cps is not destroyed by subsequent electrical surges which result when Saturn Dealer loosens the center fuse box post.
Aug 20, 2008 | 2002 Saturn VUE
2002 saturn vue
Cause of the problem:
During a non-related visit to the Saturn dealer, ie for an oil change, the Saturn dealer loosened the center of three bolts that electrically connect the main battery plus cable to the main fuse box, driver side, under hood, near windshield.
Affect of loose electrical plus cable
A loose cable, probably on the way home from the oil change, causes electrical surges that destroy the CPS and result in catastropic engine failure.
Fix:
Replace the cps. Available only from the Saturn dealer, the new cps exchange will also result in catastrophic failure when replaced.
Problem with CPS Replacement:
The Saturn dealer will bend down one of the electrical conductors on the electrical connector to the new cps. Upon insertion of the electrical connector into the cps recepticle, the bent pen will defeat cps funcetion.
Fix for the Fix
Straighten each electrical pen to the new Saturn supplied cps. Carefully reconnect the connector to the cps making certain each pen is properly inserted.
Be sure to tighten the plus center connector that holds the main fuse box firmly connected to the main plus battery cable.
Saturn will make you pay dearly and ruin your VUE engine because you shame shame shame on you because you did not pay Saturn the big bucks demanded by Saturn to renew the inadequate Saturn maintenance agreement.
Aug 19, 2008 | 2002 Saturn VUE
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
