Question about Kenmore Ovens
I keep getting an F7 error on my wall oven in the middle of baking. How do I fix this?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
I have a brand new Viking french door oven...Went to set it at 450 on bake setting and got an F02 error code. How do I fix this?
Fault F02 is indicating an overheat fault- service manual says to replace main electronic control board.
Sometimes switching off at wall will clear the fault.
However, switching off at wall will reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears. Good luck!!
Oct 05, 2017 | Viking Ovens
It's the middle of the night and pouring rain Christmas night and the F7 alarm is going off on my wall oven. Help! What do I do to make it stop?
Hi, Will forgo all the greetings. F7 is a stuck or shorted keypad. Try rapidly running / fanning your finger FLAT across the keypad to un-stick it. If this does not correct the problem you may be faced with either a keypad replacement or an electronic range control replacement.
Fault codes:
http://www.repairclinic.com/Fault-Codes#GE4
Thanks for choosing FixYa,
Good Luck!
Kelly
Dec 26, 2010 | GE JKP30WMWW 27" Built-in Single Electric...
Temp stays at pre-bake 170 degrees oven does not ignite
We are Amana factory authorized service and parts supplies. We have all the parts that you need for you oven.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will give you all the information as well as get the correct part out to you asap.
We look forward to getting you up and cooking again.
Thanks, Ella
Nov 10, 2009 | Amana AOGD2750 Gas Double Oven
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
Top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Nov 23, 2008 | GE Profile JTP56 Electric Double Oven
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
Ge wall oven display says F7
Your problem is most likely caused by a short between sections of the ribbon cable between the touchpanel and the electronic control. The solution is to insert a slip of paper between the sections where it exits the touch panel. See the attached photo. If you have a metal touchpanel, insert slips of paper on either side of the ribbon cable as well. CAUTION: Be certain to turn off the power to the oven before you poke your fingers in and around the touchpanel. My solution has worked for hundreds of folks. Don't worry about the paper burning. If you have questions, contact me at hutchipop@yahoo.com.
May 29, 2007 | GE JKP30WMWW 27" Built-in Single Electric...
Ovens Logo
110 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
