Question about Palm Tungsten E Handheld
I have the same problem. I replaced a 1100mAH with a 1400mAH and started charging the unit. In about 30 minutes it was almost hot enough to fry an egg on. Can anyone give me any help? I suspect that with the way the board is that the battery leads are soldered to has something to do with the problem. Might have caused a short in the circuit. I couldn't get a long enough charce in the existing battery to run a ballistics program without recharging immediately after.
  • Palm Master
  • 6,993 Answers
its wrong to have replaced 1100AH with 1400AH. 1400AH is to high for the unit and that's what's making it very hot.
You still have a chance of putting back and good 1100AH and your unit should be back to normal.
Take care,
Posted on Sep 14, 2010
Testimonial: "Thank you so much for the excellant advice. Sorry to say but I cooked the unit."
Why wont my dirt devil gator 18v charge?
Hello! If you are experiencing a short run time your battery may need to be reset. Try completely depleting the battery. Run the vacuum until it shuts off. Then re-charge for a full 24 hours. The indicator light will come on to indicate the unit is charging. If there is no indicator light on the charger, the charger may need to be replaced. Below is a link where you may go to purchase the charger if needed. Hope this helps!
Charger Innsbruck 1100Mah 1300Mah Cec 2013 Compliant
May 12, 2014 | Dirt Devil Dd Gator 18v Cordless Hand Vac
FRYER DOES NOT STAY HOT ENOUGH
You probably will not like my solution.
Either get a fryer with more BTUs or put less in it. You might be able to partially pre-cook the tater tots and or fry's then you only will only need a few minutes to fry them and your heat should hold. If the heat holds they should no longer be greasy (Oily) when finished.
Apr 07, 2014 | American Range Kitchen Appliances - Others
2008efi thruxton stops
not enough info, does it seem like it too hot, what color are your plugs.
Jun 07, 2013 | 2008 Triumph Thruxton 900
STD-FNB-83 1400mAh NiMH Replacement Battery Pack for HX370S Handheld VHF Radio won't hold a charge
Hi Sarah,
Don't despair, there is a solution to this sticky problem, it will cost a little more, try the Lithium Ion version battery, these can be purchased online at ebay for a much more reasonable price than in some stores.
The make of your radio is the VERTEX Standard, is that correct?
If so, you'll have no problems finding your batteries under Electronics section on ebay.
I hope you find this solution helpful.
Kind regards,
Peter
Jan 15, 2013 | Standard STD-FNB-83 1400mAh NiMH...
Was just wondering I charged my sons psp on the computer but didnt dial down the power so now it wont turn on did i just fry the battery or the whole machine?? thanx S
the computer probably wont supply enough power to charge the PSP, just plug it in to the charger and leave it for 20 minutes and it will power up
Mar 11, 2011 | Sony PlayStation Portable (PSP) Console
Coffee does not get hot enough
Replace the thermostat. there are alot of companies online that sell the part roughly about 20 dollars or so for the part and then about 30 minute install time
May 24, 2010 | Miele CVA615 Espresso Machine
Stange battery performance???? - iPAQ h2200
surely the problem is with the battery ask for a replacement, try to find one which has the same mah with the battery you got along with the phone.
Apr 15, 2009 | HP iPAQ H2210 Pocket PC
Viking freezer and fridge power on but not getting cold.
Are you sure the compressors are running, it could just be that the fans are starting but the compressor does not start.
It sounds as though you may have fried the boards again.
Remove the top grille and reach in to the compressor, to see if it is running, you should be able to feel it vibrating, there should also be some heat to it, not neccessarily hot.
have you tried putting surge protectors on the outlets, to save the boards in the future?
Dec 11, 2008 | Viking 15.9 cu. ft. Upright Freezer...
Charging player/downloading songs causes computer to crash.
You can purchase a "AC to USB" power adapter for about $30
Mar 04, 2008 | RCA OPAL M4001 MP3 Player
Palm Tungsten E Handheld Logo
21 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
