Question about Maytag Dryers
No heat,I was told it was heat element. Are there any other possibilities? THANKS
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 15, 2010
Where can I get a replacement element for this unit? I called blue rhino, and I was told that it is no longer in stock. Can you help me? Thanks
You are right, I tried all our suppliers and were told that you can no longer get them. The original part # 6NPE1605 just isn't in anyones system. One supplier said I should take the element out and take it to an appliance parts house and see if they have one that will work. BUT REMEMBER - yours is a 110V and not a 220V heating element.
Jul 01, 2011 | Uniflame NPE1605
Dryer does not heat
Well first all you may check out the heating element, it is possible that your dryer isn't heating because its heating element is defective. Heating elements are not repairable. You need to open your dryer's cabinet and locate the heating element so that you can test it. and you need a multimeter to check it out. Secondly you may check out the Thermal Fuse Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you need to replace it. Post further comments for further help or information.......
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Bosch WTMC632SUS Electric Dryer
Dryer won't heat
Good Luck!!
Jan 26, 2011 | Kenmore HE5 Electric Dryer
Fridge works fine on shore power. When turn gas
What model fridge? Sound like you have a bad 12 volt heat element or there is a possibility the board is bad but the likely is the heat element.
You can remove the cover on the circuit board and unplug the 12 volt element. Do an Ohms reading on the element. Should be 35-35 Ohms. If that is ok Turn the fridge on and with a VOM check for 12 volt power on the terminals the heat element was plugged into. If there is no power the board is bad. There is also a possibility the upper board is bad. I would start with the lower circuit board. Check for power at the heat element terminals if you have power there then I would say you need to replace the heat element. The heat element is mounted in the boiler tube and just slides uo to remove it. Good luck
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic Refrigerators
Oven problem
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Ovens
Dryer blows cold air but no heat
The heating element is in the back of the dryer. Sometimes there is a small access panel that will allow you to check the terminals to the heating element. You will need an ohm meter or multimeter to check.
Jan 02, 2009 | Kenmore 62802 Electric Dryer
GE JKS06 won't heat up past 200
Hi.
Could be that main oven stat is faulty, and also there is a possibility that the thermal overheat stat is coming in sometimes caused by poor ventilation.
Also there is sometimes a secondary element fitted to cookers which is not always obvious.
More investigation is needed.
Nov 19, 2008 | GE JKS06BFBB Electric Single Oven
RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
  1. exploded parts diagram;
  2. parts list.
Cheers.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Trips ground fault on plugging into receptacle
You have a leak on to and electrical component or an element that is bad. Stop using it due to possible electrical shock and take it to an authorized repair center or get a new one.
Jul 30, 2007 | Keurig B60 Coffee Maker
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
