A yellow vertical bar appears on left side of my screen i am using compaq 610 lap
  • go_sanju Sep 15, 2010
    Hi sir thanks for your quick reply,
    (1) yes i am seeing it even before windows loadup
    (2) yes the bar is stable at one position its at 1/3 from left side vertical bar and at same position from last 4 days
    my lap is under warrenty i am going to service station and will see whats the problm and will post the sol here, if they cant do this i will apply your changes
    thanks for your reply will post again the results after few hours
    Sergeant:
    Champion:
  • 256 Answers
There could be a lot of point of failure on this issue
-the questions are
1. are you seeing it even before windows is loded up?
2. is the bar stable there or it is kinda moving?
if you can see it even before windows is loaded, it mens that its not a video driver issue
You can open up the chasis and reseat the LCD ribbon
it colud also be your grafix card (slim posibility)
if you can only see it on windows
a. boot to VGA mode
-while booting up the computer
-keep hitting F8
-then it wll give you the boot options
-select boot to VGA mode
(it will start the PC with the native windows grafix driver)
if you cant see it on VGA mode, just reinstall the grafix card driver
-Carlo
Posted on Sep 14, 2010
Testimonial: "better solution"
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
Verticall bar on the screen
A vertical bar is frequently a sign that the matrix decoder has failed.
The usual solution is to replace the display panel itself. Dependent upon the model, sometimes this may not be economically viable.
There is also a possibility that the connexion between the display panel and the motherboard may have come loose. Try removing the connexion and replacing it before you replace the display panel.
Dec 10, 2013 | Samsung Televison & Video
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Blue vertical bar Left side and yellow,red vertical bars are seen both side of screen cause images are not readable
Hello
If the monitor displays these vertical bars, after a service has been done to it, and if LOT has replaced, there is a mismatching problem with replaced LOT and the defelction yoke.
Dec 18, 2011 | LG Studioworks 700S 17" CRT Monitor
I am using the Asus VH236H for video game playing on my playstation 3 and xbox 360. I was playing marvel vs capcom 3 last night and notice a red vertical bar appear on the left hand side of the screen and...
Flat monitors work on a grid method, if one of the grid is failing it creates a horizontal or verical line. its not something you can fix, so send it back.
Mar 17, 2011 | ASUS VH236H 23 inch Monitor
A yellow vertical line is appearing on the left side of my compaque 610 screen... how i can i remove it?
  1. Run the laptop only on battery, if there is no line then check & replace your Power plug & Power adapter.
  2. Connect an external monitor, check if display is coming OK.
  3. If Display is coming then your LCD is faulty & need to replace.
Aug 23, 2010 | Computers & Internet
Vertical Line on Lap Top
One or both of the following:
Your signal processor is failing OR the lcd display panel itself is failing. When one fails it's prudent to replace both.
Jun 04, 2009 | Compaq Presario M2000 Notebook
Yellow vertical lines on the screen of my DELL inspiron 9300
The pixels are shot - common for lower priced LCD monitors. Once it starts, it will continue. Theres no inexpensive fix for it - time to retire the Compaq
Nov 28, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
