Question about Sony CDX-M800 CD Player
2005 Honda Accord EX jammed CD player, could not eject Cd"s, pulled fuse and when I put the fuse back in, the radio came on after I put in the code but the CD Player doesn't display. Tried to display by buttons on radio and steering column. Hoe do I get my cd palyer back and remove 6 CD's?
  • 2039 Answers
SOURCE: Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Posted on Jan 14, 2008
SOURCE: Car Radio
I have the same head unit and disconnected from the battery. There was no input code required when reconnecting the battery You should be ok! I can't help with your Tuner problem though! Good Luck!
Posted on Aug 22, 2008
Ps3 Repairs
  • 42 Answers
SOURCE: Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
Posted on Sep 11, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Posted on Oct 02, 2008
SOURCE: Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Posted on May 10, 2010
Jammed cd player - 2002 Honda Accord
The same thing happened to me. Supposedly you can't put burn cd in that radio. So I need to get it fix or get a new one. I took out the radio fuse out waited about a minute, then put it back on. Now it works just fine but the only problem is that I won't be able to change the CDs that r in it. I'm stuck with the same six until I could get it fix but for now ill deal with it.
Nov 19, 2012 | 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
Oct 23, 2009 | 2002 Honda Accord
CD stuck in CD player and won't eject.
Disconnect the fuse for the radio. This is cause the radio to reboot. You do not need to mess with the battery. After replacing the fuse, or removing, it, and putting it back in, you can proceed to try to remove the CD. I used a pair of tweezers.I actually jammed two CDs into the player. Hope this helps.
Sep 28, 2009 | 2005 Chevrolet Trailblazer Ext
Cd player won't turn on
ur vehicle needs a new stereo unit..
Apr 02, 2009 | 2004 Honda Odyssey
I have no power to the the radio
You will have to chase your power wire back to the fuse panel and/or the battery itself. The burning smell was more then likely the main power cord burning up. Replace it and it should all work well.
Dec 16, 2008 | 1992 Honda Accord
My cd player in my 2005 chevy malibu wont eject all it does is clicks
we have a 05 malibu. cd got stuck and displayed locked on radio. on the passenger side floor board is a fuse box. u have to pull the panel off takes about 10sec to do. find tha fuse that says radio its a 10A fuse. pull tha fuse out. put key in ignition and turn forward. put fuse back in and hit the eject button cd will come out.
Sep 07, 2008 | Audio Players & Recorders
Cd Player
hello
does your cd player come on randomly? it sound like a loose connection on the rear of the radio? check the fuse on back of unit.....or fuse in car!! and how lond have you had the cd player?? could just be worn out!!
hope this helps
keep me informed
Damien
Aug 22, 2008 | 2005 Honda Element
Honda Accord 2002 EX-L (Canadian Model)
I think that the problem is in the connection between the cd-player and the radio antenna on the roof.
Jun 17, 2008 | 2002 Honda Accord
Sony CDX-M800 CD Player Logo
164 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
