Question about Diamond Audio CM315D2 Car Subwoofer
Whats the difference between a speaker and a subwoofer
  • 30 Answers
A sbwoofer is ment for producing bass by playing low frequency notes at an amplified power. subs move air vibrating off of your trunk and creating bass. a speakeris ment to produse high and midbass frequencies. thus having a tewwter and a small woffer cone. trying to get bss out of a door speaker usually results in very bad distortion which will actually blow a speaker very easy
Posted on Sep 15, 2010
What is the difference-between Passive & Active-subwoofer?
a passive subwoofer is just like a regular speaker that gets it's amplification from you receiver. An active subwoofer has it's own built-in amplifier
Oct 29, 2015 | Audio Players & Recorders
When the volume is low the subwoofer sounds good, but when you go up a little volume, the sound is more acute. I have two subwoofer 1000rms each, when use 500rms power aprox, it sound great, but when
If the sub doesn't appear to have any damage like broken surround or a torn spider then I would suspect the amp may be having problems. What impedance are the speakers, what impedance can the amp handle, how do you have it wired to the amp?
Feb 23, 2014 | Fusion FEW12PK Car Subwoofer
I have a kenwood KR-V8080 and i had 4 subwoofers hooked up to it. then one day it jus shut off an smoked a little. now when i turn it on an try an hook up speakers it sparks an the speaker pops. i dont kno...
You blew the amp. If you were running 4 subwoofers off of a dual channel amp you most likely running them bridged off of two different outputs. You most likely blew the resistor and because it was pushing more power then it could handle. Also when you bridge speakers it brings down the impedance which allows for the more power to course through. Suggestion is to buy a new amp that can handle 4 subs or 2 different amps for both sets.
Sep 13, 2012 | Car Audio & Video
Hooking up subwoofer to speakers
running subs with speakers is not a good idea bcs of the different frequencys of them but parrellel wiring is best prolly
+ to + and - to -
Nov 23, 2011 | Theater Research TR-2810 Main / Stereo...
I've connected a powered sub (bazooka BTA10250D) to my factory system (09 altima coupe 2.5s). I want to be able to control bass on the component speakers and the subwoofer separately. There is no sub out...
We used to use what we call bass blocker capacitors on the component speakers to block the bass coming from the head unit and to allow the bass to only come from the subs...there is several values of these capacitors that you can use(different values correlate to different frequencies). These type of capacitors are available at Radio Shack. You will need to request a NON-POLARIZED Electrolytic capacitor at a voltage rating of not less than 25 Volts...As for the value of the microfarad rating..you may need to experiment with different microfarad values to get the sound you desire...standard microfarad values are 1uF, 2.2uF, 3.3uF, 4.7uF, 10uF, 22 uF, 33uF, 47uF.
You probably won't need to go any higher on the value than those listed....in my experience, I have found the 4.7uF and 10uF to be good for most speakers...to install these...you need to put one inline with the positive lead to each component speaker.
Jan 14, 2011 | Bazooka BTA10250D Car Subwoofer
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
Subwoofer sound cutting out.
Hiya by rattling i am assuming like something loose/fell off etc (rattling sound or distortion on the speaker itself is different, speaker could be damaged or braiding damaged that 'Might" make the speaker come in and out.) Something could have come of the PC board and may not be to serious. Probably protecting as not 100%. It may be as simple as resoldering the part but if not sure on your side i would advise seeking some help. Best of luck
Jul 13, 2009 | Altec Lansing VS4121 Speaker
Loud humming sound from subwoofer
just try leaving it unplugged for a while thats what i did and it fixed it
Sep 21, 2008 | KLH PSW8100-8 Subwoofer
Subwoofer preout and bass
did you tell the receiver that you have a subwoofer connected (thru the quick setup)?
Apr 02, 2007 | Pioneer VSX-D514 Receiver
Diamond Audio CM315D2 Car Subwoofer Logo
89 people viewed this question
Top Diamond Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
