Question about RCA RS2642 CD Shelf System
My RCA RS2642 will not eject or change disks. There are no disks in the system. It is blinking on disk 5 and it does nothing. How do I get the CD changer to start working again?
2 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: I have an RCA rs2642 shelf system. It is a 5-CD
Hi Joespivey,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - because of dust build-up, the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 26, 2011
How do I get my lap top to work
That page is the BIOS "basic input output system" it looks for an operating system usually on a hard disk. Either your hard disk has crashed or there is a problem with the motherBoard and the hard disk controller. You can try removing the hard disk and putting back in as it could be minor corrosion where it plugs in.
Jan 10, 2013 | Computers & Internet
2008 cadillac 6 disk dolby dvd/cd sound system will not play or eject disk
Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Dixit
Dec 02, 2012 | Televison & Video
How can I force the CD player to eject a disk? It is stuck. I know there's a little hole next to the eject button, but it is doing nothing when I put a paperclip in it. I've tried "eject" when...
Switch off the laptop first, try probing the hole with the paperclip until you find the bar that ejects the CD, its not always simple or done 1st time
Jan 04, 2011 | Dell Latitude 650 Notebook
I have a RCA RS2664B 5 Disc Player and the disc door won't open and you can not play CD'S. Help!!!!!
unplugged the unit for 5-10 mins........ when u plug it back to ac outlet....press the stop/eject...the cd player by default is trying to load the disk again...you wish to open the disk tray..once all disk are recover try another disk to play
Sep 12, 2010 | RCA Audio Players & Recorders
The 6-disk cd changer in my '04 silverado z71 will not load or eject cds. When I push load the cd emblem on the screen goes away for a while. When I push eject it tells me there are no disks, but I have...
the laser system this damaged you have two options to repair the laser or to change to The 6-disk CD to changer but cheap is to change to the 6-disk CD to changer
Jul 05, 2009 | Chevrolet Silverado 1500 Cars & Trucks
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Khypermedia DVD RW - not being consistent
Try to re-install the drivers for the drive.
Hope this helps!
Nov 23, 2008 | KHypermedia (KDVRW8X) (20730176) DVD+RW...
Stuck game wont eject
Try tilting the wii at several angles. The disc may come out. If not try hitting the eject button at several angles.
If all the above fails, this(although risky) may work.
1. find another disk.
2. slide into slot, just enough to get under the cd(NOT ALL THE WAY IN)
3. lift or puch down on the disk depending on the side the new disk is on
4. hit eject while lifting or puching.
5. If this does not work the system may need to be sent out
Nov 02, 2008 | Nintendo Video Game Consoles & Games
RCA RS2642 CD Shelf System Logo
91 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
