Question about E-Machines T2899 PC Desktop
Turned on power button, heard it start up then sounded like paper getting caught in fan,thenpoof and had burning smell,unplugged.looked at rear of tower and saw nothing(no paper in fan) would not turn on
  • smck302 Sep 15, 2010
    thanks,do you think that it is the power supply or worse?
    Sergeant:
    Champion:
  • 251 Answers
That sounds really bad. You might try opening the case and looking for burn marks. I'd bet you will find lots of dust too. Maybe a careful cleaning operation will help, but it sounds terminal.
Posted on Sep 15, 2010
Had 1 cup coffee still heating in the pot, then heard spattering sounds and a burning smell. Turned it off.In making next pot, beans grind but won't make coffee. Water just sits in the reservoir.
Possible the "spattering sounds" you heard were in fact wires shorting out, which coincides with the burnt smell. You didn't mention the model of coffee maker. But if you can, unplug and disassemble to check. Or if under warranty, send in for repair or replacement. In any case unplug from wall to be safe.
Apr 30, 2017 | Coffee Makers & Espresso Machines
I set my brand new GE oven to bake and it almost immediately started to smoke. It continued to smoke even after I turned it off. It smelled like burning wood. It kept smoking (15 minutes) until I unplugged...
Wherever you bought it from should have a warranty. Get them out there to look at it. The smell of burning wood is odd. Check to make sure all of the packing material was removed prior to installation. That could be burning cardboard on the outer casing of the oven.
Dec 18, 2014 | Ovens
Electrical burnt smell
If you had a short in the starter motor windings and held the key, you'd get a click and a burning smell. That would be the insulation burning off the electrical windings. There's a 40-amp max fuse in this circuit.
Jul 21, 2017 | 1995 Chevrolet K1500
Just stopped working. No burning smell. When start button pushed, some kind of tiny "click" sound heard around the timer.
The click is most likely the timer motor moving the dial on the timer. The motor circuit on American dryers is 120 volts whilst the heater requires 240 volts to operate its 5k element. The motor circuit always has the fuse in it. The heating element has limits mounted on it but they only kill power to the element and not the motor. Fuses are usually located on the blower housing next to the control thermostat. MORE HERE
Nov 29, 2012 | Dryers
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
I have a Frigidaire cooling and heating unit. Last night we had freezing rain and ice. I heard a weird noise coming from the unit then smelled a burning smell. I turned the unit off. The top vent...
Sounds like the motor burned up when the ice blocked the air which it was not able to cool the motor it will need to be replaced. (the motor)
Jan 29, 2010 | Heating & Cooling
I have the same problem!
don't do that anymore! If you're lucky, there is just something caught in the vent fan, if not you will probably need a new motor.
Jun 18, 2009 | Dryers
Schematics of the pt51hx40b
check the board, maybe is burned , I have the schematics, if you want it, write me to ipbass@gmail.com, only I need the model of the board
Mar 11, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Not Cooling and has burning smell
If you are looking for help, one must explain the problem in detail, described properly, for one one the internet to review. For myself, a would require more details of your refrig, to properly explain a resolution. Otherwise a general answer is not worth much. If you have the fully electronic temperature controlled unit, then the components can be easily chedked in 5 minutes, by the on-board service diagnostic computer. One needs to know the general operating knowledge fo the refrig, which is naturally available, since you operated it for some years. Anyway, a layman can check it out by doing what is natural. Since the refrig defrosted, it has shut down. Four years is too short for genral compressor defects. Put the power plug in and check for operating sounds. Just a few seconds. You mentioned smell (outside or inside), ket a paper tube, like a paper towel center, and sniff the evaporator motor, then the condenser motor. I will recheck later, and see if you want to continue, this troubleshooting. Regards fmauka
Sep 21, 2007 | Kenmore 53542 / 53544 Side by Side...
E-Machines T2899 PC Desktop Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
