Question about Kenmore Washing Machines
I have a Kenmore Special Edition Front Load washing machine that needs fixing. The repair people tell me I need the model number or serial number for it. I have looked everywhere including under the panel. By chance is this number it W5D00015 or WBSCC000-0836-0078C? Otherwise all the other numbers are obviously part numbers.
yalmer
  • 552 Answers
SOURCE: kenmore front load washer Model 970-C40042-00
Click this link.
They will have a manual for you.
Posted on Apr 02, 2008
mikedurland
  • 481 Answers
SOURCE: Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
Posted on Aug 07, 2008
  • 10865 Answers
SOURCE: Find serial and model number
Hello. for a top loader look here
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
  • Posted on Apr 30, 2010
    SOURCE: How to increase the water level of Front loading washing machine
    I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
    Posted on May 05, 2010
    • 1937 Answers
    SOURCE: KENMORE SPECIAL EDITION TOP LOAD
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
    removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
    Four possibilities: (Ranging from easiest to messiest) None of the suggestions are very expensive.
    Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
    Older models only used the switch during the spin cycle.
    Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
    This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    It also has a troubleshooting guide.
    To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
    Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
    With the jumper in place, try to re-start the washer.
    If it works, the Lid Switch is a relatively inexpensive part.
    If the washer still doesn't work, check the motor coupler.
    Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
    It's used as a fail safe device and consists of three parts.
    Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
    transmission input shaft. Between them is a rubber piece with six holes.
    The power from the motor is transmitted through the rubber piece to the transmission.
    The other shaft on the motor directly drives the pump.
    If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
    spinning.
    See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
    If the coupler looks damaged, it's a relatively easy fix.
    Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
    Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
    Put the rubber piece on the transmission plastic piece.
    Replace the motor mounting plate.
    Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
    Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
    Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
    If the motor coupler is OK, the problem could be the clutch:
    Sears has a replacement clutch band kit.
    See the following for how to pull the pump, motor and transmission.
    You DON'T HAVE TO PULL THE AGITATORS OR TUB.
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
    Also see the Whirlpool / kenmore service manual for these washers.
    Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
    See the Following Whirlpool parts list for alternatives to the Sears part numbers.
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
    If you've tested the Lid Switch and the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
    See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
    WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
    Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
    When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
    Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
    In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
    You don't have to remove the drum.
    Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
    Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
    Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams.
    If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
    If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
    As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
    Posted on Aug 07, 2010
    A light came on to clean the washer. Is there something special I need to do?
    Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
    ? 4:57
    https://www.youtube.com/watch?v=4o9hWHQkOMM
    Sep 1, 2013 - Uploaded by And Justice For All
    Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
    Front Load Washer Pump Clean Out - YouTube
    ? 3:03
    https://www.youtube.com/watch?v=f9uS8_0-pWY
    Sep 6, 2012 - Uploaded by GE Appliances
    If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
    Nov 29, 2015 | Kenmore Washing Machines
    What year was my kenmore washer 110.26442502 made?
    need both the model and serial number,go to appliance411.com and look up your model,it will tell you the year of any appliance.
    Jun 27, 2014 | Kenmore 24032\24036 Top Load Washer
    Need age of my washer machine
    Kenmore elite model number 22054100 serial number CL210158. How old is this washer?
    Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Where do I find the serial number/ model number on my front loader?
    If this is a Kenmore front loader, the serial number is on a nameplate tag around the door opening along with the model number. You need to open the door to see it. I hope this helps you.
    Feb 04, 2010 | Kenmore 44072 Front Load Washer
    Blow breaker
    I need the model n serial # to better assist you.
    Thank you
    May 10, 2009 | Kenmore HE2 Plus Front Load Washer
    Would like to know how old a used washer is
    The model number determines the manufacturer. Your washer is made by Whirlpool. I need the SERIAL number to determine the age, however.
    Jul 07, 2008 | Kenmore 22422 Top Load Washer
    Maytag washer is leaking
    There are special tool designed to dissassemble this unit although it can be broken down without them if care is taken.
    Having the model and serial number would help but be assured that the threading is standard (Rightie tighty, lefty loosy)
    Maytag used different designs. Repair depends on the model/serial number. With this information I may be able to step you through the repair.
    Knowing the age of your machine would be a plus in determining if repair is economically feasible.
    Jan 02, 2008 | Maytag Legacy Series Top Load Washer
    Washing Machines Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
