Question about Cell Phones
My phone is displaying no sim mode when the sim card is in!
    Guru:
  • 277 Answers
Check the sim on another mobile. Alternatively check another sim on your mobile. If the other sim is also not working then there is problem in the mobile and if the sim is also not working in the other phone then sim will be dead.
Posted on Sep 14, 2010
Nokia 6350 1dr restriction code
Hi
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
SimClock
Allows you to check whether your SIM-card mode StopClock. When transferring the card to this mode significantly reduces power consumption and thus increases the work of the battery. Generally, all modern SIM-cards support this mode.
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
Displays Serial Number.
Displays the Month and Year of Manufacture
Displays (if there) the date where the phone was purchased (MMYY)
Displays the date of the last repair - if found (0000)
Shows life timer of phone (time passes since last start)
ttt
txexixs
Feb 27, 2017 | Nokia Cell Phones
Gt-s5230 no sim mode displayed withe sim card in, how can I get the phone to work please
There are three possibilities available to get no sim mode message?
1.Check your sim whether it's properly inserted or not.No means,you should take the SIM card out of your mobile device and carefully reinsert the SIM card
2.A faulty charger that is not connected properly can result in your phone displaying the "no SIM mode" error message.
3.In some cases, unlocking your phone may also cause the error message to occur.It means your previous unlocking solution was not premanent one.So try to unlock your phone with a help of premanent unlockin service provider like
SuperUnlockCodes.com
Jun 04, 2014 | Samsung S8300 Ultra Touch platinium-red...
Samsung gravity 2 no sim mode
I will help you.
There are three possiblities to get no sim mode message.
3.In some cases, unlocking your phone may also cause the error message to occur.It means your previous unlocking solution was not premanent one.So try to unlock your phone with a help of premanent unlocking service provider like
TheUnlockArena.com
May 07, 2014 | Samsung Gravity SGH-T459 Cell Phone
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
My smart roaming sim lost its signal..i dont know why but still it has a remaining balance..what should i do??
You can powercycle your phone. Turn off phone,remove the sim card,memory card, and battery. Wait for at least 5 minutes then after 5minutes,you can put back the sim card,memory card at battery. Try to check if your roaming card will again work. If this doest work you need to contact smart telecommunications and ask them to deactivate then reactivate the roaming of your sim. Because if your sim wont work,there will be no access for you to retrieve the load of your sim.
Dec 02, 2011 | Cell Phones
Nokia 6700s stucked in offline mode
You will need a new SIM card. Contact your phone service provider and explain your issue and that your SIM is locked out. You should be set once you tell them that the SIM failed message was coming up.
Oct 26, 2011 | Cell Phones
Samsung tocco lite displays no sim mode and even though I ve put the sim card correctly for several times it keeps showing that no sim mode. Can you help?
That shows that the sim compartment is bad.Take the phone to samsung care shop so that they can help you fix the sim compartment so that the phine can recongise the sim.
Jan 27, 2011 | Samsung Cell Phones
When i start my nokia n97 up i get a msg asking 'use phone in offline mode?' than boots up offline. shortly after msg displays 'insert sim card' and than 'phone will restart?'what is the problem here? i...
actually there is a problem with either ur sim card or ur phones sim card slot
1. Try putting some other sim card and donot use ur phone in offline mode .
2.If u still have the same problem then there is a hardware problem go to nokia
Jan 20, 2010 | Nokia N97 Cell Phone
Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
Apr 12, 2008 | Nokia 3250 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
