Question about Zenith A56M91W 56" Rear Projection Television
No Picture good sound
I have a Zenith 56 and it has not picture but good sound and I listen to see it the high voltage transfomer turns and it does not all does anyone what it could be thanks
I had the same problem and re-soldered the DAG and the AA wire on the circuit board and now it works fine.
Posted on Jan 01, 2011
Plug tv in and i get a large snapping sound from the back end
Hi:
This is usually an indiction of a cracked flyback transformer or splitter block, the spitter block is responsible for dividing the high voltage between the three CRT's or picture tubes. This could also be caused by a open tracing in the Horizontal scan circuit, Sometime bad horizontal caps go bad and cause this error also, there could also be a cracked picture tube at its neck, the best way is to take off the back and make the room dark as possible and stand a short distance away and have someone turn on the unit, you will see the arc of blue high voltage from the defective part.
Aug 24, 2010 | Zenith R56W36 56" Rear Projection...
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
Zenith r57w46 rear projection tv
the static sound may be due to a defect in the high voltage circuits, IE Fly-back transformer or and voltage multiplier, posibly high voltage leads to the CRTs arching to ground, finally horizontal sweep circuits
Apr 28, 2010 | Zenith R57W46 57" Rear Projection...
The sound is perfect but no picture although occassionally when switching on the picture appears for a second or so. again on occasion a amall glow will appear centre bottom of screen
Call Zenith Exchange Moduel 1-800-632-6637,Replace the power suppy board the one that has FBT flyback transfomer on it ,It will have Board number on it.I have used this company in the Past they are a good company when it comes to replacing board then to try and fix it yourself.
Oct 05, 2009 | Zenith IQC50H95W 50" Rear Projection...
Tv repair
I posted this many times.
the sound is basicly one circuit. the picture is thousands.
I always suspect a short in the high voltage system of the set first if sound is working.
Jul 26, 2008 | Zenith R56W36 56" Rear Projection...
Zenith IQB32b84R dead
check high voltage transformer
Oct 17, 2007 | Zenith B32A24Z 32" TV
Sound No Picture
The FBT (high voltage transformer) is bad.
Sep 06, 2007 | Zenith A56M91W 56" Rear Projection...
NO PICTURE...BUT SOUND
Your HV circuit is defective. Most likely horizontal output transistor is shorted and you may need to replace the flyback. You need to call an expert.
Jun 06, 2006 | Zenith R56W28 56" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
