Question about IBM ThinkPad R40 2722 Notebook
Problem with some keys of keyboard
I have LG IBM R40 bought in 2004. Presently I am facing a Problem with some keys of keyboard. As there is no proper devoted service center for LG IBM after the breakup of LGIBM, I am finding difficultly in getting proper assistance. Some forum says try installing drivers but I was unable to follow so I gave laptop to a TG service Center for confirming if keyboard is real problem or not, Now they say, they want to install XP but my CD drive is not working. They ask me to change the CD drive(which I hardly use!). I am just confused if I should really change Combo CD drive, the keyboard or what to do? I already changed my Hard Dive 2 years back and also upgrade RAM to 512MB.
1)What can be way to solve the problem?
2)Whether it is worth to change the parts?
OR
should I try to buy new one?
  • nanoguy May 16, 2008
    Model is ThinkPad R40 2722-LK4
  • nanoguy May 19, 2008
    Thanks for assitance- The keyboard problem was solved just by using PC doctor. It was only problem related to NUM Lock key
    To solve just press hold SHIFT key and then press NUM lock,
    My all keys of internal keyboard are working fine now.
    Thanks again
  • 37 Answers
1. Sourcing a keyboard is easy, check EBay. Fitting it is easy, two or three screws from underneath and a single connector takes care of that. I just did one, and the keyboard cost me 20 pounds.
2. If you don't use the CD / dvd drive, then consider purchasing / loaning an external cd / dvd drive, which you then connect via USB. You can then reload Windows from this new device, and it will serve any new computers you may have in the future. Expect to pay 20 to 30 pounds from any high-street retailer.
To boot from this device (which you would want to do in order to load Windows from it), you will need to access the BIOS, and change the 'boot order'. So you interrupt normal boot, by pressing F1 (could be different o your comp), and make the USB cd / dvd the first device in the boot list.
Good luck.
Posted on May 16, 2008
HI, I AM SANDIP FROM CENTRAL ACCOUNTS OF DURGAPUR STEEL PLANT A UNIT OF SAIL having IBM Thinkpad type 2682 ,Product Key GXR3W-GHM34-7RFFM-BVCQJ-WGF4G. PROBLEM- WHEN I AM SWITCHING ON THE POWER A ...
As soon as anything appears on screen after power-on, press F1 (keep clicking it until the BIOS setup screen appears). The first option on the list is Date + Time, click on that, and enter correct date/time. Then press F10 to accept + reboot. If this error happens again, it means that the CMOS battery (which keeps your settings alive) has died; it is cheap + easy to replace, however you have an R40 model, and I avoid working on Rxx series so that job may be harder. I could point you to the R40 service manual, which is very good to dis-assemble that laptop (it is necessary to lift keyboard to get to CMOS battery, which involves removing some screws from the bottom.
May 01, 2017 | IBM ThinkPad R40 2682 Notebook
'<-' left Arrow key ..is out from keyboard, can
hi there fit on the top that key & they give a press. there is clip. it will goon during press & lock.
Jan 15, 2011 | IBM ThinkPad R40 2722 Notebook
Utilisation de clavier mon clavier qwertz ne fonction pas
Take the notebook to a qualified IBM technician, to replace the keyboard. This is not a "self-service" repair.
Oct 20, 2010 | IBM ThinkPad R40 2722 Notebook
I bought a used IBM R40 whose hard drive failed. I tried installing someone else's XP Pro on my computer and then trying to use my license key from the bottom of my machine. It didn't work. I get the now...
must use an OEM install copy of the version on your key sticker. retail and upgrade versions will not work. i had the same problem with my r40. had to use e-donkey file sharing program to find it.
Aug 07, 2010 | IBM ThinkPad R40 2897 Notebook
The keys with nunbers/ & letters on the right of keyboard are
The num lock key up by F12.
Usually you press and hold the shift key and the correct key.. It will be in the upper right of the keyboard.
Sep 03, 2009 | IBM ThinkPad R40 2681
Bios battery location
On the R40, you will need to remove two things to get to the BIOS battery: 1) the regular battery, 2) the Keyboard. The BIOS battery is located just underneath the keyboard. In order to remove the keyboard you have to remove two screws from the bottom of the notebook (each will have a little picture of a keyboard and arrow next to it). Pop the keyboard up gently and the BIOS battery is just above the mouse buttons.
Check out the service manual for more details (pages 68, 77, 85).
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-45899
Apr 28, 2009 | IBM ThinkPad R40 2681
I popped the key cover off an IBM thinkpad. How do I replace it?
The white hinge assembly likely has two parts to it that make it form a spring in the form of a letter X. You should see small catches for the feet of these two parts on the keyboard -- they will fit properly only one way. Put that back on. Then you can snap the key itself back on and it will be "springy" just like the others.
Mar 24, 2009 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 2722 Notebook Logo
348 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
