When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
the charger port is located under the front of the joystick. with the charger off plug the 3 pin connector into the charger port then turn the chrger on or plug it into the wall. You should see a red and a yellow light when the yellow light turns green the batteries are charged turn off the charger and remove the plug from the joystick See my tip on charging Hope this helps you
Could be the charger or the charger port. Do you have the offboard charger that plugs into the joystick or an onboard charger? I would suggest trying to find an offboard charger from a friend or your provider that you can borrow and plug it into the charger port under the front of the joystick to see if it will charge the batteries. the meter will not work if you use an offboard charger the lights on the charger will turn green when it is fully charged. when the charger is plugged into the joystick and you turn on the chair the lights should scroll indicating you have the charger inhibit function working and hopefully the chair is charging. If you can charge the chair with the offboard charger then look into buying one and using it instead of trying to get the onboard charger working Hope this helps
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Carla Under the front bottom of the joystick you will see a charger port its a three pin port that accepts the plug from the charger. Always plug the charger into this port with the charger off or not plugged into the electircal socket. Then plug the charger into the electical socket or turn it on. You should see a red light and a yellow light on the charger. When the tellow light turns green the batteries are charged. You should get into the habit of charging the batteries each night if you use the chair daily. Just plug in the charger when you go to bed and turn it off when you get up. If you only use the chair a little then always store it fully charged and then charge it once a week if it hasn't been used. Hope this helps you
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine.
Hope that works for ya!
Cpl. Ramos
