Question about GE Microwave Ovens
Need help on installing under cabinet microwave oven.
  • GE Master
  • 9,098 Answers
If yours is a GE you can find installation and owner's manuals here.
Otherwise, please reply back with your brand and model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
SOURCE: Microwave installation
Hi there - just figured out how to get mine out. Here is what I did. There are two screws at the top under the faceplate. There is brace on each side with 2 screws on the bottom and one facing out. Remove the two that face out. Next look under the unit and there is a brass looking cover with 2 more screws. Mine had writing on it about servicing professionally. Remove that two screws, the two power connections and the unit should slip right out.
Posted on Oct 08, 2007
  • 833 Answers
SOURCE: gap between cabinet and top of microwave oven
eastlake...only if you think so. Most of these units use a submounting bracket set and then you hook your oven to it. This is a rather nasty installation...I've done several. If it's sturdy, you may just want to put in a filler piece.
Posted on Dec 13, 2007
  • 619 Answers
SOURCE: Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Posted on Jan 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: otr microwave install
We have a partial service manual for that model on our site at http://www.microwavedisplay.com/MV1615x_Service_Manual.pdf
It shows an exploded view of the installation on page 8-7 but for some reason the parts list (with part numbers) is missing.
But this page *should" answer your question.
If yours is not a Goldstar MV-1615, please reply back with your brand and model.
Posted on Feb 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: how does the microwave remove
Assuming it's not just a greasy / charring waveguide cover (stirrer cover) then smoke is most likely a problem with the high voltage transformer, which is pretty expensive.
The installation instructions are very handy and will show you how it's installed.
It's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on May 13, 2009
Can you provide under cabinet mounting instructions for GE Microwave part WX4-A19?
To mount it under a cabinet, you have to have the under cabinet install kit; you'll find that here: Under Cabinet Mounting Kit WX4 A019 GE Appliances the kit does include instructions. You can't mount it without the kit.
Dec 12, 2015 | GE Microwave Ovens
I NEED A 24 IN. WIDE COUNTERTOP MICROWAVE TO BE INSTALLED UNDER A CABINET. NO VENT NEEDED. I WAS NOT LOOKING FOR A DRAWER TYPE UNIT. I CANT FIND AN INSTALLATION KIT TO INSTALL ONE. THE ONLY KIT I COULD...
Sharp has a model 1214 that could work, but it is a little over 15" deep and will therefore not recess entirely into a 12" deep upper cabinet. I believe the install kit comes with it?
Jan 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can the Dacor DCM24 be installed in a 19-inch deep
yes / but install still need some air flow in and around the unit . needs air under neath and over the top / and cannot have 0 clearance in back / / ****
Jan 10, 2010 | Dacor DCM24 Convection/Microwave Oven
No sure how to remove oven from under cabinet in motor home
If you need further help, reply back with your model number.
Dec 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Aug 27, 2008 | Microwave Ovens
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Gap between cabinet and top of microwave oven
Dec 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
