Question about Kitchen Ranges
Kitchenaid Selectra Range Fuse location?
I have a range model # KERI501DW2 from Kitchen aid and the oven and control panel does not work at all, the elements work fine, it just stopped, I was going to replace the fuses but cannot find them. Is this the problem and do you know where to look for the fuse on this appliance?
  • jarhead0311 Nov 23, 2008
    i have a smooth top kitchenaid selectra. the top and control panel work but the oven itself doesnt. when i have the broiler/oven turned on i feel heat on the top not in the oven. BUT the "burners" are not "lit"......... they dont show color but i feel heat on the top. any idea whats wrong? it worked perfect before and we dont use the oven that much.
    jeff
    USMC
  • 45 Answers
Unit does not have fuses , if the top works ok then you are getting 220 volts , you probly have a bad control
Posted on May 16, 2008
Hi, I have a Selectra 30 and the panel has gone dark and the oven door is locked. If I unplug it and remove the back cover I can unlock the door manually. When I plug it back in the door locks again and...
First of all, why did you post a question about an oven under a dishwasher question? What is a Selectra 30? That is not the model number. The model number of the dishwasher in the subject does not help. Without knowing anything else, I would say you have a bad control board.
Dec 17, 2014 | KitchenAid Kitchen Aid Superba Series...
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Door locked after self cleaning&panel went blank
NEVER use the self cleaning feature, again!!
Jan 27, 2011 | KitchenAid KGRS807SSS Gas Kitchen Range
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
Blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Jul 14, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Aid KESC 307 hbs4 electric range control
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Mar 28, 2008 | KitchenAid KERC607 Electric Kitchen Range
Kitchen Ranges Logo
1,098 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
