Question about Boating
Suzuki 2 outboard, can't get the prop off, it's seized, any idea how to remove it?
  • 433 Answers
Aluminum prop??
Try,
Heat
liquid wrench
vinager
take you time, it will come loose sooner or later.
Posted on Sep 15, 2010
How to Change the impeller on Suzuki 140 outboard motor
Suzukis are normally a mission to work on especially if it is a two stroke,so I suggest you get a workshop manual.all gearbox bolts must be undone,the gear linkage is under the bottom carb,this is the tricky part,you have to loosen a nut at bottom of gear arm where gearcable fits,then push in with screw driver,this releases gear change shaft.the biggest problem is trying to see what you are doing.good luck
Oct 08, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
Suzuki outboard 8hp 1994, at higher speeds under loading prop appeared to cavitae, liek spun prop. repalced with new prop. On the bench, plugs removed, in forward gear hand turn prop thur haft turn and...
You may not be deep enough in the water and it really is cavitation.
May want to check the lower oil for metal as a Mostly worn out gear can do that
It's normal for a gearbox in forward to "click" in one direction and be firm against the motor when turning against the gears normal rotation.
Oct 10, 2012 | Light Boating
Need Parts diagram fo 25 H.P. yamaha lower unit
Most modern outboards had 2 tapped holes in the casting which would let you put a steering wheel puller on that part wit some all thread and push aginst the end of the prop shaft to get that piece off the lower.o
Sep 04, 2012 | Boating
15hp power old mdel bt in good cond.if run on full the engen dont want to push the vessel like before what must i do ?
If rev-ving up as it idles the same and can get you moving normally in low speed when in gear...then increase the speed, always under load (in the water) and if you cannot get the same thrust most common proplem would be the propeller (prop) spinning hub slipping problems to plain prop damage/wear and tear.
If you are convinced it is not an engine problem take the prop to your local marine dealer that has a good parts manager. Bring all info (model/serial number). If you are lucky it is a torn or loose hub.
Marine dealerships have a deal w/ prop machine shops that usually come in once or twice a week. Depending on the business the business or condition of the propeller they might offer to sell you a new one (may not be in stock) usually 2 day shipping. That is another option. I have seen 15 hp steel props (usually heavy use in salt water) I would ask for the parts MANAGER.
Removing a prop from a small outboard: Use needle nosed pliers and straighten the key evenly ...any type of plyer remove key ...may have to use regular pliars for leverage. Use a socket wrench to undo the the nut. Use a crescent wrench at an angle if not available. Remove prop...If stuck spray w/ lubricant and let stand overnight. Use a hammer and chisel while revolving the prop a few times. if it does not free itself quickly (Do not desroy your prop shaft).
I mostly know small OMC Evinrude/Johnson outboards from the 40's through late 80's....Always include a model number and at least the make of the brand. I have no deal w/ fixya.com as an expert but just offering free advice hopefully someone helps me.
Feb 20, 2011 | Light Outboard Motor Boat Bass Fishing...
Boat motor while in water revs extremely high after about half throttle with no additional thrust
It sounds like the prop bushing is bad. There are 2 systems for preventing gear damage,shear pins and rubber prop bushings.
The rubber bushing can be molded to the prop or there is a type that has a sleeve the prop fits over. If the prop has no sleeve you need to take the prop off and have it relined. It will fail soon, its just a matter of time. If you have the removeable sleeve, you replace the sleeve and just slide the prop over it and you are done.
The diminished thrust is due to the rubber slipping from its bond and it will get looser and looser.
May 04, 2010 | Light Outboard Motor Boat Bass Fishing...
Suzuki outboard dt 60 no power
try removing the prop when you want to barrel test it . we (evinrude) dealer had to use test props or remove on bigger engines . or run in river /lake
Mar 14, 2010 | Boating
2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
131 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
