Question about LG Prada KE850 Cellular Phone
Clock problem... Hello, date on the phone keeps rolling back a day randomly, i keep setting it and then i look and its a day back. Also my alarm clock doesnt work all the time. Please help.
How do i set the Barbie Glamtastic alarm clock radio
Barbie Glamtastic Alarm Clock Radio 11765268
There are four (4) buttons on the back:
  • Mode
  • Set
  • Scan
  • Reset
Everything regarding setting dates and times is done starting with the Mode button, and using the Set button to adjust various settings.
Set Year
  1. Press Mode until the date appears.
  2. Press Set. The year will begin to flash.
  3. Press Mode until the correct year is reached.
  4. Press Set.
Set Date
  1. Press Mode until a date appears in the form of MM-DD.
  2. Press Set. The year may flash first. Press Set again. The month (MM format) will begin to flash.
  3. Press Mode until the correct month is reached.
  4. Press Set. The day (DD format) will begin to flash.
  5. Press Mode until the correct day is reached.
  6. Press Set.
Set Time
  1. Press Mode until the time displays.
  2. Press Set. The hour will begin to flash.
  3. Press Mode until the correct hour is reached. Keep in mind the AM/PM indicator in the far left of the screen. Make sure that the hour to be selected is with the correct AM/PM indicator.
  4. Press Set. The minutes will begin to flash.
  5. Press Mode until the correct minute is reached.
  6. Press Set button.
Set Alarm
  1. Press Mode until the the Alarm screen displays. The Alarm screen has an AL in the far right of the screen.
  2. Follow steps 2-6 above under Set Time (these same steps are just being done on the Alarm screen).
Turning Alarm On and Off
The left side of the radio has an On/Off dial (for the radio) at the top, and a slide selector button (for turning the alarm on and off) at the bottom.
  • Sliding the selector to the far left will result in Barbie's voice as the alarm.
  • Sliding the selector to the far right will result in a piercing noise as the alarm.
  • Sliding the selector to the middle slot will result in the muting of the alarm.
There are graphics on the left side of the clock that denote each result above.
Mar 28, 2014 | Barbie Glamtastic Alarm Clock Radio...
How to adjust date and time free of charge
You did not specify the phone you using.
To set date and time on your nokia phone
Select Menu > Settings and Phone > Date and
time.
Select from the following:
Time - Enter the current time.
Time zone - Select your location.
Date - Enter the date.
Date format - Select the date format.
Date separator - Select the symbol that separates days, months, and years.
Time format - Select the time format.
Time separator - Select the symbol that separates hours and minutes.
Clock type - Select the clock type.
Clock alarm tone - Select the tone for the alarm clock.
Alarm snooze time - Adjust the snooze time.
Workdays - Select your working days. You can then set an alarm only for working day mornings, for example.
Automatic time update - To update the time,date, and time zone, select On. This network service may not be available on all networks.
Regards
Jun 30, 2011 | Lands Phones
My I Pod docking station keeps beeping
The beeping is the clock telling you to progam it to find the clock page. With the iPod docked, hold the down for a couple of seconds, it will double beep and the select prompt will move to some random page and then back to the inital menu. After the double beep, press the which will roll the selct bar down to the "extras" menu item then select (press center circle) on the iPod twice which should be the clock. When you have got to the clock page, press and hold the until it double beeps again.it the
If you do it right, whenever you dock your iPod, the alarm clock willl remember how to show the clock (different generations of iPods have the clock in different menu locations).
Mar 07, 2011 | Accurian Audio Players & Recorders
HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Calendar/clock keeps changing to wrong date (Nokia 6220 classic)
ok mate its probly ur settings ave ya got it on manuel and if ya do dat wud probly be the problem switch it to auto update and time and that shud do it for ya tell us if it works for ya
Mar 13, 2009 | Nokia 6220 classic Smartphone
Date keeps changing a week forward after setting time
A possible solution to this issue could be changing the automatic update of time and date. If it's currently switched on on your phone, try switching it off. And if it's already off try switching it off.
Here's where to find the setting: Menu >> Applications >> Clock >> Options >> Settings >> Automatic time update
For more info, check the (English) N79 manual on page 147
Feb 26, 2009 | Nokia N79 Cellular Phone
Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Oct 28, 2008 | Zenith Z166S Clock Radio
Motorola Razor v3 clock setting problem dilema
Disable the "Automatic update" feature and set the clock manually.
To do this go to Menu, settings, initial setup, time and date, Autoupdate>Off, then set the clock and date.
May 01, 2008 | Motorola Mobility RAZR V3
Emerson Research SmartSet Clock Radio
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
Oct 28, 2007 | Emerson Smartset Clock Radio
LG Prada KE850 Cellular Phone Logo
95 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
