Question about Thetford Norcold RV Cooler/Freezer
Describe your Thetford Norcold RV Cooler/Freezer Problem My 8662 won't get cold in the refrigerator, but the freezer gets cool-not cold either. The manual says to check the evaporator plate and make sure it is level in every direction. I would do this but the manual fails to tell me where the evaporator plate is located. Do they mean the coils and are they underneath the refrigerator?We are trying to leave for a vacation and are already a day late. Hopefully someone could answer my question ASAP. I would be eternally grateful!!
  • gpgruver Sep 14, 2010
    When you say door "side" or "backside" do you mean in the door or againstg the back? If so There isn't anything like that unless I need to remove a part of the refrigerator to get to it.
    I need more complete instructions as I am not very mechanical.
    Also, could you give me the title for those numbered parts in the ilustration?
    Thanks
    We do not have a defrost problem.
    Refrigerator does not work-Freezer works partially on both electricity and propane-same thing. Refer won't get cold at all.
  • 3,083 Answers
This site has a general troubleshooting guide on it's page:
http://www.rvcool.com/
From what that states, the coils are behind the back plate, and here are some pictures that may help you:
The last two blogs on this site might be what's going on with your unit:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24361223.cfm
Clean the tube and flue 1 and see if that helps.
Good luck, and thanks for using FixYa, and hope this gets your unit working (and have a great vacation!)
Posted on Sep 14, 2010
  • 944 Answers
It will almost look like this not exacly same it will be located on door side or the back side based on the model.Hope this will help you out.You have a defrost problem.Switch of the Norcold
for some hours it will defrost the system and it will start working.
Enjoy the vacation..
Need a 8662 manual
http://bryantrv.com/docs2/docs/8682.pdf
This will get you what you want. It covers both the 8682 and h 8662.
Jul 10, 2014 | Thetford Norcold RV Cooler/Freezer
Does overloading a refrigerator cut down on it's cooling effects?
Often times it can take a day or so to catch up after loading it heavy...
heatman101
Sep 08, 2010 | Thetford Norcold RV Cooler/Freezer
I have a Norcold 611 and the freezer works fine, but the refridgerator wont get cold. Any answers?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold 682 is 0 in freezer and 50 in fridge cranked all the way up over 48 hrs now where do i look now
How about checking the R12 charge? Or you can run the fridge on propane and see if it gets colder. Which might mean your compressor is going bad.
Apr 15, 2010 | Thetford Norcold RV Cooler/Freezer
I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER FREEZES FINE AND THE COOLER COMPARTMENT WILL GET COOL BUT NOT COLD AND THE ADJUSTMENT SWITCH IS ALL THE WAY UP. THE SAME ON GAS OR ELECTRIC. CAN YOU HELP ME....
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Oct 16, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold rv cooler code needs reset reading no co
u need to take into dealership or have a tech reset the board if not done right u can blow your board out
Sep 19, 2009 | Thetford Norcold RV Cooler/Freezer
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold RV Cooler/Freezer Logo
131 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
