Question about Dewalt DC616kn 18 - volt 16 - gauge straight finish nailer
DC616 WILL NOT DRIVE 2 1/2" NAILS IN.REPLACED THE ACTUATOR BUT STILL HAVE THE PROBLEM
3 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: the pin on my Dewalt
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
Posted on Feb 09, 2011
  • 4 Answers
SOURCE: My DC616 a straight 16 gauge DeWalt finish nailer
Argh...
Had the same problem, but only after about 4-5 nails. Once it jammed 4 times in a row - very frustrating.
I read the manual, took the unit apart, checked the driver - it was straight. I took a file and filed the back end of the driver down a bit so it would miss the second nail and so far it seems to be working famously.
Great unit...
Posted on Mar 20, 2011
My dc616 dewalt nailer is not firing and constant flash not battery no jambed nails what else could it be
look at the end where the nail comes out . it should be flush across , if the plunger is sticking out then push it back in with a flat screw driver and try again.soft wood quite often lets the nail shoot to far
Aug 13, 2015 | Dewalt DC616 16g Cordless 18v Straight...
2kd-ftv engine problem p1226 fuel line malfunction
Possible causes of the P1226 code include:
  • Faulty electric throttle control actuator, throttle position sensor 2
  • Faulty throttle control actuator harness is open or shorted, throttle position sensor 2
  • Electric throttle control actuator circuit has poor electrical connection, throttle position sensor 2
To nail down the exact cause of the code, do a visual inspection for lose wires and connections at the sensor, or damage to the sensor body itself. If no problems with the wiring and connections are detected, a worn/damaged electric throttle control actuator is likely at fault. Signs of a bad throttle control actuator include erratic acceleration, and unresponsive throttle, and poor fuel economy.
Sep 23, 2012 | Cars & Trucks
DC6t16 nailgun I have a nail stuck lengthways in the magazine. This stops loading nails. How can I remove it
The bestthing to do is get you a good screw driver and just sit down and start prying it out of there, will take a minute or 2 but will eventually come out
Jul 26, 2011 | Dewalt DC616 16g Cordless 18v Straight...
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
Feb 09, 2011 | Dewalt DC616 16g Cordless 18v Straight...
How do i replace the driver blade in a Dewalt DC616 finish nailer?
I believe the manual has a whole section on how to remove it and replace it.
You will probably have to buy a whole driver/return mechanism.
Dec 31, 2010 | Dewalt DC616 16g Cordless 18v Straight...
My DC616 a straight 16 gauge DeWalt finish nailer tries to drive 2 nails when it fires 1 out of about every 5 to 10 shots. I am a finish contractor and have used this nailer for about 6 years. I was...
Argh...
Great unit...
Sep 07, 2010 | Dewalt DC616 16g Cordless 18v Straight...
Remington Powder Actuated Tool Model 476D. Ram set. Drives concrete nails with a 22 size charge. Barrel seems to be clogged. Looking for a manual that shows the interior cross section. There is not a...
the tool got stuck, after a shot, it stayed up and I cannot release it to put a bullet and a nail for the next shot, what can I do, I tried to undo the nut in the top of the tool with no success.
Mar 06, 2010 | Remington Powder Actuated To Power Load...
Dewalt dc618 nailer is not firing
I have both the DC616 and 618 and have used them sucessfully for about three years. Two main things go wrong. There is a drive belt that breaks (drives the spool that give the energy to drive in the nails), second are two small rubber bands on either side of the drive head that break. The bands can be accessed by taking off the front silver cover, the drive belt is access by spliting the case. Make sure you are using the correct nails or the drive pin may become bent and will jamb repeatedly. Hope that helps!
Nov 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Dewalt DC616kn 18 - volt 16 - gauge straight finish nailer Logo
79 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
