Question about EliteGroup A530 Notebook
Computer turns and boots up Windows goes on-line and after about 5 minutes, will turn offHave to wait till cool down to turn on...sometimes over night...Computer tech just says it's internal, buy another one...said it was the motherboard and not cost effective to replace, till I found one , then just said buy another one...??
  • Iftikhar Ali
    Iftikhar Ali Sep 14, 2010
    does the computer shuts down after giving some messege?
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 18, 2010
  • thomassle296 Sep 21, 2010
    I build custom cars and motorcycles ....but always use a manual....no where on the net have I run across a manual for this laptop...as this is my only laptop, do not want to do a show and tell.....not into just pulling all the screws and popping the cases apart... !!
Asus x553 has been showing configuring windows features 100% complete don't turn off your computer message for 24 hours
Hi
This sometimes happens when updates are not successfully downloaded or installed. I know it says don't turn it off, but this is the only way you'll get it back. Hold the power button down for at least 5 seconds until the power goes off. Wait a minute or two and start the machine up. Upon boot you will probably get a screen asking if you want to start the machine normally, in safe mode and several other options. Try start Windows normally first, and if this doesn't work, Last Known Good Configuration. If this fails as well then you will probably need to go into safe mode and uninstall some of the latest updates.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 01, 2015 | Computers & Internet
Dell 530S powers up and goes blank
how long have you given it to boot after it goes black? you may just have to wait a few minutes as windows may be configuring something on boot.
May 03, 2012 | Dell Inspiron 530s Desktop Computer...
Is there a way to change windows xp bios settings after boot up, particularily using the command line?
My knowledge of using the command line is equal to my knowledge about astrophysics. Zero.
You can change BIOS settings in the BIOS Setup utility. After the computer manufacturer's splash screen, (Logo screen), and at the bottom of the screen, are shown the key/s to press to enter BIOS Setup.
Goes by real F-A-S-T. Try to write it down. Let Windows load all the way, then restart the computer.
As SOON as you see the manufacturer's splash screen, start tapping on the key/s to enter BIOS Setup. If you miss this window of opportunity, let Windows load all the way. Turn the computer off normally. (Wait at least 20 seconds) This time as Soon as you press the Power On button, start tapping on the appropriate key/s. (In 2 second intervals) You don't get as far as the splash screen? Then unplug the computer from power. Observe Anti-Static Precautions. Remove the CMOS battery, (CR2032), for 1 minute. Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. Let go of the Power On button. Do this procedure two more times. Install the CMOS battery. Plug into power. WAIT 1 minute, turn the computer on. This procedure will set the BIOS Settings back to the factory default settings, and clear CMOS Error Codes. Post back as to your findings.
Sep 14, 2011 | Computers & Internet
Car won't start. It turns over but won't start. Wait 10-15 minutes and it starts.1998 Honda Accord EX
There is a possibility of a condition called "Vapor Lock" in which on hot temperatures, air bubbles form inside the fuel line, and dont allow the fuel to reach the injectors. One the line cools down, the vapor goes away, and car starts uneventfully. Have the fuel lines checked for leaks or abnormalities. The other possibility is that the EFI (Electronic Fuel Injection) relay or computer unit is acting up. These units usually start to fail when hot, and work normally after the engine compartment cools down.
Sep 20, 2010 | 1998 Honda Accord
Upgraded to win 7 now princeton monitor goes black how do i fix
try this, but a bit tricky.
start off with the pc off
then turn it on
wait till the bios etc splash screen show past the hit del or f2 to goi to setup then after that press f8 repeatedly until it shows some sort of list
this is the alternate boot up just scroll down to ENABLE VGA MODE
after selecting that it will boot up with your screen..
hope that works
Nov 10, 2009 | Computers & Internet
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Repeated boot
I supposed you are using windows xp, put the Win XP cd in your cd drive and start your computer
boot on the cd drive, wait until the winxp finishes its copying
When asked if your want to install winxp or repair [R] choose repair by pressing R
wait till the command line and type: chkdsk /r
wiat until it finishes, it may take about 20 to 30 minutes..
reboot your pc
Oct 25, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Fails to boot
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Apr 16, 2008 | Gateway MT3705 Notebook
Open Questions:
EliteGroup A530 Notebook Logo
35 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
