Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I replaced the lamp in a wd52525 and still have know picture. the lamp is on but the screen is just full rectangles. what could be the problem?the green light is on and not blinking.
    Sergeant:
  • 171 Answers
You have a issue with your DMD board, it looks like this board is not functioning correctly some of the micro mirrors are getting stuck I don't think you can buy just the DMD board I think you need to replace the LIGHT ENGINE
Posted on Sep 14, 2010
Change lamp on TV model WD52525 reset does not work
follow this steps and fix it. God bless you
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Jul 31, 2013 | Televison & Video
Wd52525 when powed up set tries turn on. it tries for 2min then powers off with the red led solid at shut off
Most probable a lamp failure, part number according to encompassparts.com is 915P020010.
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6543337&smodel=WD52525
I have had issues also with the power supply having failed capacitors, tops of caps will bulge up rather than be flat. The most common failure is a popped lamp or defective lamp. Inspect the anode of the lamp, it may have fractured or is swollen at the base.
I buy lamps on line from a company called niosales NEIlamps and electronics.com
Jul 12, 2011 | Televison & Video
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture and no sound after replace lamp for Mitsubishi WD-51525
did you use an original mitsbishi lamp. did it slide in easily? one of the most common problems with a lamp replaement is pushing the connector away from the lamp if it doesn't slide in easily. unplug the set, take out the lamp and look with a flashlight to see if the connector is in place. if so put the old lamp in and see if it works. if it does then your new one is bad. if it doesn't then email me
ima_rm2000@yahoo.com with your number and we can talk more.
ken
Nov 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
maybe this help you, let me know. good luck
ok here new tips on v26 chaiss cust install new oem lamp with led lamp just blink only many time install new balister still shut down no audio no hv at all come with code 34 for test turn out to be that in power supply ther caps that wher blow up 3300 mf at 16v two them c9a38 ad c9a36 both same also note c9a62 1000mf at 16v thru c9a52 ad c9a82 ad c9a61 all 1000mf at 16v install 63v at 1000mf all same with both 3300mf at 25v fix the set now turn on with great pix cust old lamp too dark for pic install new lamp pic better ad reset lamp timer all good cust happy that cust got from mist the power supply board from looking from back of the set on left hand side all way in front u hav pull whole dmb bd to get to it want lets yu guys know[john leyva american video service center ] the right model number is this WD52525 HIT BAD KEY THIS RIGHT MODEL NO WD52525
Sep 09, 2008 | Televison & Video
Mits wd52525 bulb replacement
Good Day Cawhite;
You replaced lamp and still get flashing light.
1. TV's 'ballst may be bad.
2. If lamp comes on for 2-3 seconds, the problem will most likely be the caps in the power supply. (to see lamp turn on you have to take off back or front (inner panel).
Hope this was helpful.
Good luck, Big Irish.
Jun 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replacment lamp
Check your ballast and air filter. I am checking to see if I can get some detailed info on your set. It is a WD52525 correct?
Jan 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
