Question about Garmin nuvi 1390T Car GPS Receiver
Garmin 3790t is taking a long time to find satellites. did not do this at the beginning. same location.
  • James Fox Sep 15, 2010
    yes, thanks, working fine now
  • Garmin Master
  • 6,993 Answers
Maybe there us no strong signal or reception at the moment. Or the antenna might not be sharp enough to search for satellite.
Secondly, I would suggest you reset the unit, if that doesn't solve the problem, then you might try updating your garmin nuvi.
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck.
Posted on Sep 14, 2010
Garmin firware update
Use garmin express or garmin web updater.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
https://support.garmin.com/support/searchSupport/case.faces?caseId=%7Bf9ca1dc0-4020-11e2-e8a7-000000000000%7D
Feb 25, 2014 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
My Garmin Nuvi 3790T will not acquire a satellite signal
Does the GPS work outside of the vehicle?
Where is the GPS mounted?
If the GPS is under the dash, mounting it up on top of the dash will help.
If the Vauxhall has a windshield with a reflective metallic coating or treatment in the glass, this may result in poor GPS satellite reception.
Apr 12, 2012 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
Do i get a free map update for the just purchased Garmin nuvi 3790T How about speed camera.
Garmin provides free online map updates (if available) within 90 days after purchase. A purchase is recorded when the Garmin Nuvi detects a certain travel speed or when the Nuvi is registered at MyGarmin.com
To qualify for free Map updates, register the Garmin Nuvi at MyGarmin.com using serial number and owner name.
A map update is a large download - which can take considerable amounts of time. When updating a Garmin map with a PC one needs at least 5Gb of free space at the C drive.
Jul 09, 2011 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
Hello, I have a Garmin nuvi 3790T GPS and also the cable with built-in FM receiver. How can I receive traffic alerts? Do I need to purchase anything? Technically I am a novice, hope you can help. Thank...
To make it work, buy a subscription on a traffic alert service (RDS - TMC) available in your region/country at garmin.com. For crossborder service buy the traffic service there too.
Its possible to buy a lifetime variant - meaning it will stay active for your receiver.
Jul 05, 2011 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
MY GARMIN 3790T WILLNOT STAY PAIRED WITH MY SONY ERICSSON SATIO BLUETOOTH EVEN THOUGH THEY ARE SET TO AUTOMATIC RECOGNITION. GARMIN SAY THEY HAVE NOT TESTED THESE TWO ITEMS OF HARD WEAR FOR CAMPATABILITY...
The nuvi 3790T shouldnt have any issues with your phone, try your phones bluetooth setting to see if the nuvi is set as its handsfree device. Also make sure the phone has enough power to use bluetooth, when the battery is low bluetooth wont work.
Hope this helps!
Dec 09, 2010 | GPS
My gps works up to the point that it cannot locate satellites. It asks if I have travelled 100 miles or more and whenI hit no, it goes back to searching for satellites with no luck. Is that a fixable...
Try answering yes. If the original location has been lost due to battery replacement etc, These devices go to a home location which may be anywhere to begin looking for the satelites. It could take 30 minutes or more to locate itself. Just turn it on and let it look for a long time.
Jun 03, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Why does my GPS system have a difficult time locating satellites?It says ''acquiring satellites'' for about 5 minutes. Then it says it can't locate satellites. Should it continue trying? Why does it do...
this is what my navigon says about gettting the gps to connect.
Initializing the GPS receiver
In the upper right-hand corner of the display, the GPS symbol appears. As soon as
data from at least 3 satellites is received, the symbol changes to (GPS Ready). Note: If possible, position the device with a clear line of sight to the sky to successfully
receive messages from the GPS satellites.
Note: GPS initialization requires data from at least three satellites. If GPS data is not
available, the receiver will not initialize.
Note: It can take up to 20 minutes to initialize the integrated GPS receiver for the first
time.
Note: Each time you turn on the device, GPS receiver initialization begins. When GPS
data is available, reception starts within one minute.
If the navigation device has been switched to standby for more than a week, the next initialization
can take up to 10 minutes.
Jun 19, 2009 | Garmin GPS
Cannot locate satellites
I can help you fix the satellite problem with your Garmin Nuvi 265WT.
Poor or inaccurate GPS tracking, and taking a long time to acquire satellites, are issues that have been addressed by Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running better than new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Nov 23, 2008 | Garmin nuvi 260W GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Locating satellite
Initialization time has been greatly reduced with newer system software upgrade for the Garmin GPSMAP 545s. Get your system software upgrade here.
I hope that helps.
Aug 30, 2007 | Garmin GPSMAP 545s GPS Receiver
Garmin nuvi 1390T Car GPS Receiver Logo
1,068 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
