Question about LG Dryers
Lg dryer i have an lg dryer dle 5977b.It will buzz when i push the start butten,but wont tumble.If i hold down the door switch and manually turn the drum it starts and runs normally until it must be started again.It sems to work fine once it is started but can no longer start by itself without my help.I have taken it apart and found no problems with lint or obstructions.Thanks,Robert
  • robertd1 May 16, 2008
    if the motor is going out do you know where i can find a motor ,how much it will cost and a manuel to help me replace it?
  • 145 Answers
Sounds like you have a motor going out. If you take it back apart see how hard the motor is to turn by hand. Also look for lint in the motor by the start switch.
Posted on May 16, 2008
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
My dryer initially makes a buzzing sound and will not begin the cycle until I give it a few turns manually...
you have a bad motor,if you open the door,hold the door switch in with one hand and spin the drum with the other and have someone else push the start button on and if by helping it to spin it starts usually the motor is bad but i did find on the maytag neptune style dryer that the belt cut into the belt pulley and was holding up the drum and the motor was buzzing like it was bad but like i say usually it's the motor.next time send the brand name and model number and i can help you out better.
Jan 25, 2014 | Whirlpool LER5636P Electric Dryer
DLE 5977B ELECTRIC DRYER wont start
On the exhaust is a limit that trips with bad air flow. I think that puppy is resettable:
LG service manuals
Aug 15, 2012 | LG DLE2532W Electric Dryer
Drum wont turn.pust start and hear a buzz but drun wont turn
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Oct 01, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
Dryer Does Not Tumble When Pressing Start
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
May 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
168 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
