Question about Kodak EasyShare C360 Digital Camera
Memory card is protected reset switch on memory card and had upward pointing arrow - but i don't know what button to push to reset it
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
It's not a button on the camera, it's a switch on the memory card.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Sep 14, 2010
Service center in dubai
I can only guess what mean by "memory slot problem" because you have not given any details, so I can only give you general information. If your problem is that your SD card does not work, I would suggest you start by reformatting the card in the camera. First, make sure that your SC card is not write protected. Hold the SD card so that you are looking at the label with the angled corner on the right top. Look along the left edge of the card and you will see a slider switch. It is very small so look closely. On most cards, there is an arrow on the label pointing downward with the notation "Lock". If the switch is in the lock position, slide it all the way up to allow you to send information to the card and replace the card in the camera. SD cards formatted in a computer often do not work because the camera's format function writes slightly different encoding to the card. Push the Menu button on the left side of the camera's back (just below the top button) and scroll to the Setup Menu and Format Memory Card. A warning message will be displayed. Use the up switch to select "yes" and push the center OK button.
Aug 25, 2014 | Nikon DSLR D90 Digital Camera
Tells me the protection switch is not functioning. i cant take pics or record. i need to know where the reset button is at.
please take out memory card from camera,
check on left side of memory card, there is Lock bar, slide it upward to unlock memory card protection and insert memory card in camera to solve this issue.
Thanks.
Feb 08, 2011 | Cameras
Camera says memory card is protected (reset switch on memory card) I don,t understand
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 09, 2010 | Kodak EasyShare CX7430 Digital Camera
Replaced the batteries & now a message reads memory card is protected (reset switch on memory card)
check your memory card a lot of people dont realize there is a little button on the side that if pushed up or down it locks the card so it cant be writen over .
Dec 02, 2010 | Kodak EasyShare CX7530 Digital Camera
My memory card is write protected how to remove its write protection?
Some cards have a little white slide button at the side of card flip it the other way.
Apr 14, 2010 | SanDisk 2GB microSD Memory Card
The camera is locked and i'm unable to make video or take pictures. The screen shows me "write protect"
remove the memory card and connect it to a pc using a card reader and check if it is working or u have a same problem
Jul 15, 2009 | Olympus Stylus 1020 / µ[mju:]1020 Digital...
Card locked
There's a little yellow switch on the left side of your memory card labled "lock" with an arrow pointing down. Push it up. Note: If it doesn't work right away, try uploading all your photos to your computer and then dumping them off of the card.  Push the switch up again and it should start taking pictures again.
Dec 05, 2008 | Canon PowerShot SD1100 IS Digital Camera
I have a stylus 410 when turned on it displays 'write protect'
The memory card is corrupted and the only way to remove the write protect is to format the memory card when it is in the camera. To format the memory card:
Press the green arrow button to go to review mode then press the Ok button
Press the right arrow button to go to Mode Menu
Press the down arrow button to go to the Card tab
Press the right arrow button to go to Card Setup
Press the right arrow button to go to Format option
Here you will see Format Yes or No
Press up arrow to go to Yes and press Ok
The camera will indicate Busy because it is clearing the write protect and erasing all images permanently from the card.
Once completed the card will be able to be used again.
Sep 23, 2008 | Olympus Cameras
Stylus 600. When I turn camera on a blue screen comes up with a message [xD] Write Protect. What does this mean and how do I make it go away?
In order to remove the message of write protect you will need to format the xD memory card. The card has somehow become corrupted. To format the memory card - press Ok - right arrow to Mode Menu - down arrow to Card tab - right arrow to Card Setup - right arrow to Format - Up arrow to Yes and then press Ok. This will permanently delete all images from the memory card and you will be able to start taking images again.
Jul 12, 2008 | Olympus Cameras
Kodak EasyShare C360 Digital Camera Logo
112 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
