Question about Riccar R1570 Mechanical Sewing Machine
My machine is about 20 years old but in very good condition, i have never had trouble with tension untill about a month ago, but now i cant seem to rectify it i have broken a few needles trying to sort it, it clogs up and the bobbin turns around and the needle breaks!!!
  • 161 Answers
It sounds to me like something may have been accidently changed. Double check bobbin is clean and in correct position. Also see if there is a thread caught in one of the tension guides, by pulling a thread carefully through the machine towards the needle.
Rather than breaking needles, test the tension by putting foot down and pulling on thread by hand , if its too easy to pull through something is causing the tension to be too loose
Posted on Sep 14, 2010
Why does it knot up underneath?
If your machine is creating a mess of thread under the fabric, the upper thread tension is too loose and is causing what is called "thread nesting" or "bird nesting." Tighten the upper thread tension (righty-tighty) and test. Keep adjusting until the upper thread and bobbin thread meets in the middle of the fabric.
You might also try this method as some machines will create thread nests when the first stitches are made:
How and Why to Bring up the Bobbin Thread
https://www.youtube.com/watch?v=jZws5pT1Ics
Aug 29, 2015 | Sewing Machines
My tension is too loose, have tried adjusting the dial and still cant tighten it. have a brother fashion faces machine lx 3125. it is relatively new three or four years old not much use
Check the upper tension discs for lint: Raise the presser foot to open up the discs and blow or 'floss' between them. Any lint or thread in there will prevent them from giving the proper tension.
Feb 25, 2015 | Brother Compact Sewing Machine Fashion...
I'm in trouble deep-I was trying to fix an old
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
My tension is way off. The machine is about 35
Set the tension to 4 and then try this - thread the machine with the presser foot up.
If this still does not work, call the service dept and tell them they missed something when they worked on it before - have your receipt at hand.
Mar 02, 2010 | Kenmore Sewing Machines
Can not adjust the tension
Nothing is too old, that is what the internet is for. You can google it or you click this link (PFAFF Manuals) which I found for you. Just look for your model and easily download the owners manual after purchase. Don't lube any part of your machine until you have a manual which shows you where. Oil attracts lint and could cause it to operate in a difficult manner.
Aug 18, 2009 | PfaFF Sewing Machines
Help! Tension Problems
Looping on the top means there is no tension on bottom. The bobbin thread generally rotates counter clockwise. The thread must get under the tension spring. The spring must be adjusted equal to the top tension. This you will have to play with to tighten or loosen as needed. When you sew in a zigzag you might want to loosen the top tension slightly. On a regular basis remove the bobbin case and clean with a qtip. On the race put one drop of sewing machine oil. Clean the bobbin case and replace.
Mar 25, 2017 | Singer 57815 Mechanical Sewing Machine
I have problems with my tension settings
upper tension needs to be tighter
Jan 16, 2008 | Sewing Machines
Sewing Machines Logo
129 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
