Question about D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
I have a dlink dap1522 bridge. I recently upgrade to an imac and upgraded my dsl router as well to a netgear N. I tried configuring my bridge again, but i'm not successful. I followed every instruction on the manual. When I plug in the dlink, it brings my whole network down. This is when I type in the IP address on the browser as instructed. What am I doing wrong?
marked
  • 6487 Answers
SOURCE: D-Link DWL-G700AP Access Point
You need to connect the access apoint directly to a pc with a CAT5 cable then set up a static ip on the pc which I assume you know how to do it, for the static ip put 192.168.0.5 subnet is 255.255.255.0 and gateway is 192.168.0.1 then save the settings, then check first if there's a good connection between the access point and pc, go to the command prompt then type PING 192.168.0.50 if you receive 4 replies go now open the http://192.168.0.50 if you receive 4 request time out reset the access point and and ping it again if still 4 request time out after you reset it replace that access point.
Posted on Jun 07, 2008
tech curly
  • 298 Answers
SOURCE: Assigning an IP address to a computer
if you comptuer is runnin on winxp you can try the steps on this link. click here.
Posted on Jul 25, 2008
  • 61 Answers
SOURCE: Cann't access the IP address that dlink instructs me to type in m
Try 192.168.0.1 or 192.168.1.1
Posted on Jan 03, 2009
SOURCE: Unable to access DLink WBR 2310 Configuration page
Reset the router first, press the reset pinhole on the back for 10 seconds using a paper clip, don't press it too much or it will mess up the settings of the router. then try to access again the configuration page.
Posted on Feb 10, 2009
  • 131 Answers
SOURCE: can't connect to configure password for linkys wcg200 ver2
The default adress for your router is 192.168.1.1 Try that one and you should be able to get into your router.
Posted on Feb 19, 2009
How to create wireless bridge
DD WRT is a firmware upgrade sight you can find wonderful firmware upgrades that make your router come to life and Evan worth more than you payed for your original router, check the router database and see if your router is listed and capable for an upgrade to dd wrt, i did it with my dir615 and it gave me a whole host of additional optins for configurations , it was a long search for "dd wrt" but well worth it.
Oct 12, 2013 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Using a router as a wireless repeater/bridge
Try out this lifehacker artical. I am copying the link to my evernote, so I can try it at home.
http://lifehacker.com/5563196/turn-your-old-router-into-a-range+boosting-wi+fi-repeater
Feb 28, 2012 | Computers & Internet
Unable to use wireless router on laptop with dsl service
If you have recently bought the Netgear, you have 90 days free support. They will give the configurations to fix this. Or you may call your ISP provider, (internet service provider) and they can bridge your router
Feb 19, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Jun 12, 2009 | Linksys WRT160N Wireless Router
Netgear wgr614 v6 As Bridge for XBOX
I'll take a stab at this. It's a bit difficult because I don't know what your level of expertise is. You're actually using the Netgear wireless ROUTER not a bridge. Your ISP can use a couple of methods to give you service. DSL companies like Verizon probably use PPPoE which require you to login and provide a password and VZ is notorious for closing down port 25.
O.K. Did I mention I don't like them very much? Anyway, I'm going to give you a link to Netgear's excellent web site for configuring a router and the XBOX connection. This is the whole list of v6 compatible instructions. Note the very bottom link to use Netgear routers with XBOX.
http://kbserver.netgear.com/products/wgr614v6.asp
Note under the Troubleshooting topic that there is a configuration and two setup files, depending on what you're connecting to, and some tips on what to do if it doesn't work.
It's not as bad as it looks.
Carl
Jan 04, 2009 | NetGear WGR614 Router
How can i configure dlink WAN settings?
I cannot find the version of the dlink..but it an older one...it is Dl-614+
Nov 09, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
D-link DI-604 problem
I had a same problem a couple of years ago with a DLink router and upgrading the firmware solved it.
The Philippines are covered by DLink's Australian office.
http://www.dlink.com.au. Look in the Support section, you will find the latest firmware and instructions on how to upgrade it.
If you don't find what you are looking for on their tech support web site, you will at least be able to contact them from there.
Feb 22, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Slow Internet
upgraded the latest firmware in the router, reset your router and reconfigure it, check if your dsl modem is configured in a bridge mode if not configure your modem in bridge mode and reconfig your links router accordingly, that will fix your problem
Nov 26, 2007 | Computers & Internet
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
74 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
