Question about Roper Kitchen Ranges
I put a load of clothes, nothing large or overbearing, in the dryer yesterday and the dryer started just like normal. when i went back to the laundry room, about 45 minutes later, the dryer was making some horrible grinding/squealing noise and i could tell the drum was not turning. i turned off the dryer and opened the door and the inside of the drum was not even hot. i noticed that the dial for the dryer timer had barely moved towards off, compared to what it normally does. now, when i try to start the dryer, it won't even give me a click, let alone start. help please!!!!!
  • 2 more comments
  • jennireed105 Sep 14, 2010
    pulled the back off the dryer and the belt is still attached/not flopping around from what i can see. unfortunately can't see underneath drum. looked around drum and there is no obstruction that i can see. what now?
    i have pulled the back off of the dryer and can see the belt. it appears to be in tact and attached/not flopping around, although, i cannot see below the bottom of the drum, without removing the drum. i have looked around the top and sides of the drum and there is no blockage or obstruction. what now?
    i have followed previous advice and opened up the back of the dryer. can see part of the belt and it appears to be where it should be and from what i can see around the drum, there are no obstructions. i am at a loss. please tell me what now?
  • jennireed105 Sep 15, 2010
    there is no sound. there isn't even a click when you try to turn the darn thing on! very frustrating!!!
  • 2,299 Answers
Can you hear a sound, it will be real faint. The electric motor that turns the drum may have broke.
Posted on Sep 14, 2010
  • 1 more comment
  • Rodney Clark
    Rodney Clark Sep 15, 2010
    Does the drum turn freely? You should be able to turn the drum. When you turn the drum does it feel like it is binding?
    i have not tried to turn it yet. i can check it tonight and get back to you. i am not near the dryer right now. i will let you know this evening. thanks!
  • Rodney Clark
    I am sorry that I didn't get back to you faster. If the drum is hard to turn then you may have burnt up the electric motor that turns the drum. I will try to get back with you faster the next time.
  • 11,800 Answers
The squealing noise was the belt slipping on the engine wheel - the movement of the drum is blocked by something. It won't give you a sign of life because the controller has been damaged by the malfunction and its safety is preventing it from starting until the problem is fixed.
You need to dismantle the drier completely to find out what is blocking the movement of the drum and if you can fix it. At least the belt will have to be replaced.
  • Azrael SRL Sep 14, 2010
    Take out the belt and try to turn the drum by hand - if it doesn't spin then find out why.
  • Azrael SRL Sep 15, 2010
    So the drum can be turned by hand without a problem and when you do that you don't hear any funny noises. That means that the problem is either in the motor or the programmer.
    You don't hear even a click because the programmer doesn't receive power - follow the wires from the wall socket to the programmer and test them for continuity. If the wires are intact and the power reaches the programmer but the engine isn't powered then it' s defective and must be replaced. A new one can be obtained directly from the dealer. But, with a bit of luck, you can find it online at a lower price.
    Refitting it is a delicate job that requires at least basic experience - if you don't have it then ask a friend who has done that before for a helping hand.
Electrolux Washer dryer EWW 1273 banging
I think a sensor is being faulty when you load and go to use the unit. Also might want someone to check out the timer on the unit just in case it is going out on you.
Aug 08, 2012 | Washing Machines
Roper dryer RAS7133RQ1 won't start
For starters, a user manual for your dryer can be found here.
Jun 02, 2008 | Dryers
Was drying cloths yesterday and restarted it due to the cloths not being dry set it on the hottest setting, went outside and came back in and dryer was stopped...checked the breaker switch, thought it may...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Magic Chef Dryers
Kenmore Dryer Model No. 110.64632300
If it is 6 years of age or older and have a lot of use in the past you will be better off replacing it. The cost to repair it will outweigh its age and cost to repair
May 20, 2010 | Magic Chef CYE4000AWW Electric Dryer
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Dryer quite
my dryer worked fine before xmas but washed a load of clothes and temped to put clothes in dryer and put it on right settings and pushed button to start it and nothing. We tried the breaker and shut everything down for about 5mins. and started it back up and tried the dryer again and still nothing had friend look at it and looked online and I think it maybe the start button myself.
Dec 27, 2008 | Dryers
Kitchen Ranges Logo
21 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
