Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Frigidaire refridgerator Model #FRT16CRH, how to clean freezer insulation
While I was out of town there was an extended power outage and my refridgerator completely thawed, the contents rotted and mold covered all. The mess drained out of the doors on to the floor. I got the whole thing cleaned, but can't figure out how to get to the insulated area between the fridge part and the upper freezer part. I really want to clean that area.
Thanks
Carleen Claybaker
  • 45 Answers
That part is the hart of the unit and more trouble than you want to get into. i do not suggest that you try and take it apart, you could really mess things up, would be very unlikely that anything got between there anyway
Posted on May 16, 2008
Why does freezer keep cold and not bottom on a frt16crh
Maybe too much food jammed in to allow cold air to get to the bottom.
Oct 04, 2014 | Refrigerators
I had the same problem everyone else is having with my samsung model RS2534WW refridgerator. After a power outage the freezer failed but the fridge worked fine. Then another outage and both sides quit...
I had a similar problem also after a power outage, I called best buy for service and 200 bucks later it was a no go, same problem. I found a repair manual on the online auction place E b a y and was able to troubleshoot down to a faulty relay on the PCB, look there for the manual it may help you. I is not the compressor cause then the freezer would not work also.
Jan 25, 2011 | Samsung RS2534 Side by Side Refrigerator
FRT16CRH Top Freezer Frigidaire Water leaking underneath refrigerator front bottom right hand side
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Frigidaire Refrigerators
Frigidaire model FRT16CRH. Top freezer not getting cold. Blows cool air. Everything that was frozen is now melted. Bottom part of refridgerator is fine.
Your refrigerator has a defrost timer and it may not be going into defrost every 8 to 10 hours. I was not able to get a picture for you of the location, but look inside the fresh food compartment and inside the teperature control panel should have a hole with sometimes a plastic plug stuck in it. If not there it will be under the kick plate at bottom of fridge. Take a flat head screwdriver and slowly turn to the right until refrigerator stops running. After about 30 minutes if it does not restart, star by again turning slowly clockwise until it starts. Let me know what you find, Thanks, Sea Breeze
May 17, 2009 | Refrigerators
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Freezer bad smell
the defrost pan is located under the frig. if there is a cover at the bottom on the front remove it and the pan should slide out
Nov 17, 2008 | Frigidaire Freezer Refrigeration White...
Frigidaire Chest Freezer Door Insulation smells like fish
might sound stupid but take the cover off the compressor electrics and make sure no plastic is overheating.
Oct 08, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Mar 07, 2008 | Refrigerators
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
301 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
