Question about Garden
Toro GTS 6.75 mower - how do you get the grass to go into the catcher instead of the mulcher?
    President:
  • 1,545 Answers
Change the blade from the mulching blade to a conventional discharge blade. They are quite different in design. Also, a cover plate on the deck will have to be removed in order for the new blade to work (plus the grass has to discharge somewhere,,,eg ,,,side or back.
Posted on Sep 14, 2010
How do i adjust idle speed on a toro recycler lawnmower model #20027
There is an idle screw on the carburetor. It will push the throttle arm to increase the speed. You might have to remove the air cleaner to see it.
Sep 08, 2014 | Toro Garden
Anyone have expierence replacing the impeller on a Toro z master model 74183? This mower vacuums the grass into the rear catcher. The impeller that moves the grass is what I'm referring to.
you have to open bottom to get to impeller once you do that remove the nut and bolt that hold it on you might have use a impeller remover to get off but they hardly ever go bad
Aug 27, 2014 | Garden
Troubleshooting toro
Check with the person that did your service and make sure they used mulcher blades and not reg blade as that could cause the problem
Apr 10, 2014 | Garden
How to engage grass catcher on toro 22
Lift rear door, catcher bag has a hook on each side that must be hooked over bar on each end.
Jun 17, 2012 | Toro Garden
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 | Mtd Garden
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
I have a Toro 22 in Recycler Lawn Mower Model No. 20331 I can't pull the starter cable, it seems locked. My boys were mowing the lawn earlier, some very high grass, and the mower stopped
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Jun 25, 2011 | Blount International Oregon Gator Mulcher...
Mulching blade replacement for Toro GTS 6HP
goto toro website and use model of machine to get blade model and use blade model in google to get prices and then order them
Jul 06, 2009 | Garden
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
