Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Motor was humming move contacts worked for few days turning on and off.The motor will not hum or come on. I think it is the start cap.
  • AO Smith Master
  • 1,343 Answers
MOTOR SHOWN IN PICTURE HAS A RUN CAP.IT HAS NO START CAP(ONLY 2 SPEED DO) WIRES AND TERMINALS MUST BE CLEAN , USE SAND PAPER AND CLEAN THEM UP. LOOK AT THE WIRES IN THE BACK OF THE MOTOR ALSO. USE A VOLT METER TO CHECK FOR POWER SEARCH YOUR ZIP CODE FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING. BRING THE CAP IN FOR TESTING.. GOOD LUCK
Posted on Sep 15, 2010
I have a HBS 20 fan. I've had for a few years but seldom used. I turned it on last week and it made this humming sound. After a few minutes it started running just fine. However, now it does not hum or do...
It ispossible that the capacitor for the motor is weak . You can access and replace this capacitor if the motor is humming and getting warm. replace with the same value and test. If it does not work then check the windings of the motor, if short within or or between the windings. The fan must work if there is no friction-- in which case you must lubricate- and the power comes over from the switch. I hope you try this out. Good day
Aug 16, 2010 | Vacuums
Kenmore dryer model 86950100, when I push the start button it just hums and will not start.First time it did it I waited 1/2 hour then it ran fine for couple days and now it started again, just hums. I...
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
Mar 26, 2010 | Kenmore Dryers
I have a 1.25 hp motor for my pool. When I turn on the electric switch, the motor hums but won't turn. I have to take off the end cap and use pliers to get it to start. Does it need to be replaced?
It's most likely the centrifugal start switch malfunctioning. It's stuck or, has burned contacts or, loose spring or, it's broken. It's right on the end of the shaft on the back end of the motor.
Often it just needs the contacts sanded and/or the the moving parts lubricated.
More info, let me know.
Charlie
Aug 25, 2009 | Pool & Spa
Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Jul 06, 2009 | Emerson Pool & Spa
Was using the SteamVac and it just stopped doing
Bad news! The humming is the pump so it is still good, but that means either the ac to dc converter is bad or the motor went up. The good news, neither would be your fault.
Apr 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Hoover SteamVac Dual V Carpet Cleaner just hums when I turn it on
if the motor doesn't run sounds like you either have a bad motor or your motor armature might have gotten wet and created a dead spot.if you have any contact cleaner spray a little on the armature then turn the motor by hand make sure its uuplugged first if you can turn the motor then plug it in and try to start it
Apr 04, 2009 | Vacuums
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Dashboard Hum
change the fuel cap
Jun 20, 2017 | 2006 Hyundai Tucson
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
229 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
