Question about Dell Computers & Internet
I have Flat screen 14" monitor When I switch the power on the screen is blank but it changes through the four main colours and the Monitor power switch will not turn off . The Monitor is 5yrs old
    Scholar:
  • 119 Answers
It's not detecting the computer, Have you tried removing and reconnecting the vga cable usually has a blue tip on it with two screw looking apparatuses that twist.
try that first, second trouble is to check the video card.
Posted on Sep 14, 2010
Colour on my screen is wrong its mainly a green colour im noticing, it over powers most of the colour on screen.
Most monitors have colour balance settings, these can be accessed by buttons on the monitor, trying looking around and adjusting colour balance, hue and other settings
Feb 28, 2011 | Televison & Video
Monitor powers on but screen is black. then a grey stripe appears across the screen. by pressing the leftmost button a faint picture shows the auto-reset? screen, a dell screen, and i can see the main menu...
Hi! I believe that the monitor has come to its end. 6 years is quite long for a monitor. You may have it repaired for there may be blown capacitors that needs replacement but a new monitor will be a great idea. HOpe this helps and have a good one!
May 18, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
Light on power on switch keeps blinking, screen blank.
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
May 01, 2010 | Acer AL1716 17" LCD Monitor
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Dell monitor E196FPF when computor turns off monitor stays on screen keeps changing colours,have to turn main power supply any ideas please.regards phil
This sounds like a "Screen Saver" in the monitor ... go in to the monitor's Setup and disable the screen saver.
Dec 10, 2009 | Computers & Internet
After monitor is turned on, it goes blank after a few seconds...
Sounds like the cable that connects the monitor to the computer hass a loose wire connection in it.
When it turns green, try flexing the cable near the connectors and see if the color changes on the monitor. I suspect that you have a wire in the cable that was not soldered properly by the manufacture.
If it changes color, I'd contact who you bought it from and have them replace it.
Hope thid helps. Bud
Jan 08, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Dell E196FP TCo99 Monitor screen problems
The screen colour changing is apparently an auto test procedure on the monitor and was prompted by a fault with the monitor not automatically shutting down when the computer is shut down. The settings on the monitor have been adjusted to rectify this and the problem is now gone.
Apr 06, 2008 | Dell E196FP 19" LCD Monitor
Chi me monitor goes blank on screen save (does not come back on)
damaged power board replace it or replace the monitor
Apr 02, 2008 | Smart Modular SV3170A
The OSD Main Menu button keeps popping up every 5 seconds and whenever I exit it always takes me back. I've searched everywhere and found no solution just more people with the same problem so if I actually...
f1703 monitor >> too simple!!! Unclip the front cover that sits around the front screen. >Becareful not to break the clips.>Remove the adjustment 715L1009-1-B (MANNEQUIN KEY BOARD) it has 2 screws and unclips from opposite side of the board. >> Clip back the surrounding cover.
Job done, no more OSD MAIN MENU ON YOUR SCREEN.
And you do not need to replace the board, your monitor will work just fine.
Nov 29, 2007 | HP Pavilion F1703 17" LCD Monitor
I have the SAMTRON 56 V 14" COLOUR MONITOR .
change the eprom (A41dDC) after connect pc then switch on monitor
sushil91077rajbanshi@rediffmail.com
Sep 04, 2007 | SAMTRON 78DF 17" CRT Monitor
Computers & Internet Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
