Question about Orion 8004 Car Audio Amplifier
I have orion 8004 connected to 2 ev`s and it wont turn on everything is connected correct but the amp doesnt turn on,It just blinks red every 5 mins and one knows what could be wrong ? or how much to fix ?
  • 30 Answers
Check the ground this is the most important part of a system! it shold be grounded directly to the fame and to bare clean metal NO PAINT! then check the ohm od from the subs. make sure it not too low for the amp to hadle. if its too low the amp could go into protection. if not the amp couldbe internally shorted or the power supplies might be shot. i cant give you an exact price bt my guess would be $100-$200 depending on he exact probm
Posted on Sep 15, 2010
How to program a Orion flat screen tv with ccd remote control
make sure your tv is on.. On the remote control, press TV once.
. Press and hold set until the l.e.d. red light blinks twice,
then release set.. Enter the first four-digit code for your tv
the l.e.d. will blink twice. If the l.e.d. did not blink twice, repeat steps 2 through to 4 and enter the code again.
.point the remote control at the tv and press power once.your tv should turn off. If it does not, repeat steps 2 through to 5...i think these codes might work for you set .0236, 0463.
Nov 08, 2016 | Orion Televison & Video
What inline fuse should be used for 12V power supply from vessel to EV-200 ?
First, type-1 is not an hydraulic system. It's electro-mecanic.
The EV-200 needs 2 power supplies. 1 for the calculation unit ( thru the Seatalk OR by a connection in the ACU ) AND a feed for the pilot motor/pump.
The calculator power ( NMEA ) needs only a 5 amp fuse. The 'high' power needs an eventual 25amp fuse. In fact, the power output to the motor is totally protected from overloads and/or shorts. Have those cables between power distribution and ACU thick enough to handle 20amps on his length ( twice the cable distance between battery and Acu is the lengt to calculate with )
Sep 20, 2017 | Boating
I just got my PPI dcx 300.2 amp back and i hooked it all up, and connected the fuse back in and started the truck, the amp turns on but the red light starts blinking and says clip out. The amp doesnt smell...
Are you sure everything is correctly connected. If you are running the amplifier in bridge mode then take note that the load to the amplifier can be no lower than 4OHM. dreamsystems
Feb 25, 2011 | PPI DCX-300.2 Car Audio Amplifier
Codes
To control an Orion tv with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0236, 0463
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Nov 30, 2009 | One For All URC-3021 Remote Control
Tv code
The codes for an Orion TV for the URC-3021 are 0236 and 0463.
To control tour Orion TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
0236 or 0463.
Hope that helps.
Nov 19, 2009 | One For All URC-3021 Remote Control
Need Universal Remote codes for Orion tv- One for All Remote
The TV codes for a URC-3021 and an Orion TV are:
0236, 0463
These are the steps to program your remote:
To setup your URC-3021 for a TV, these are the steps:
1. Turn on your TV.
2. On the remote control, press TV once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 through 5, trying each code until you find one that works.
Oct 05, 2009 | One For All URC-3021 Remote Control
My epson emp-50, gets off after ev.5 mins. says NO SIGNALS. but audio comes....pl.help
check for the error indicator in the projector, if the bulb light is flashing red, then i think you need to clean the units ventilation fan, if cleaning doesnt solve the problem, you have to replace the bulb.
Jan 29, 2009 | Epson (V13H010L13) Projector Lamp for...
Tv wont turn on after fixing convergence problem
Check the pins with a strong magnifying glass to make sure they are solderd correctly with none of the pins bridged with solder, then recheck all the wire connections to make certain they are correctly hooked up.
Apr 16, 2008 | Samsung HC-P4752W 47" Rear Projection...
Orion 8004 Car Audio Amplifier Logo
54 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
