Question about Sony VAIO VGN-FW140E/W Laptop
My grandaughter's Sony VGN-FW140E laptop will not boot up after being turned off unless it is unpluged from adapter, the battery removed, allowed to sit idle for 3 or 4 hours then put the battery back in without the power adapter and then turned on. It will then boot up o.k., but if it is turned off or allowed to go into sleep mode you have to repeat the steps above to get it to boot again. I am fairly computer savy but this has me stumped. Any help would be appreciated.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
Reset bios password
If you take the laptop to a repair shop, they can pull the CMOS battery for several minutes and then put it back in, which will reset or clear the password - this should not be attempted unless you're certified in laptop repair
Oct 24, 2013 | Sony VAIO VGN-FW140E/W Laptop
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
I want to know the BIOS password for my laptop model No VGN-FW140E
To reset the BIOS read the information from this link.
In case of your Sony Vaio laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 07, 2010 | Sony VAIO VGN-FW140E/W Laptop
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 09, 2010 | Sony VAIO VGN-FW140E/W Laptop
My sony vgn-tx17p won't boot. Te power light turns on and nothing shows up on te screen. Please help
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM/memory.
  4. without the battery or ac adapter, press and hold down the power button for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
Feb 26, 2010 | Sony VAIO PCG-TR3AP1 Notebook
I want to reset password Bios of VGN-FW140E. How can o do? Please help me. I need a backdoor passwords.
Sir,
if you can open your laptop search for jumper in the laptop and remove it and turn on you laptop the password will be removed and you will be able to enter in you system again and now if you want to plug it in back you can do that to.
Nov 11, 2009 | Sony VAIO VGN-FW140E/W Laptop
Vaio sat survey has stop working
Do the following:
-unplug adapter from the wall
-unplug from the computer side
-remove the battery
-With everything unplugged and battery removed, press the power button.  Keep holding it down for 15 seconds
Yes, nothing happened, that is ok. :)
-re-insert the battery first
-plug the adapter to laptop side first
-plug adapter to wall socket
Now, turn on the laptop and see if it powers on.
Jun 28, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Sony VAIO VGN-FW140E/W Laptop Logo
211 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
