Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Hi, Don't know if you can help me but I have a question. My oven model KitchenAid kebc107kss04 is displaying a temperature that is higher than is measured in the oven with a manual thermometer while baking. The deviation is not constant. it various between 75 - 35 degrees less than is read out on the display. The higher the temperature is set on the oven the lower the deviation is. Don't know if I should replace the temperature probe or the PC board/ electrical panel. Any suggestions?
  • KitchenAid Master
  • 1,711 Answers
This a 50 % problem of the probe and 50% problem of the PC board. It excactly as you figure it out.
the correct procedure in any case is to proceed first with the probe test for a couple of days and then if no diference you should replace the PC Board.
In this you dont loose anything since in the second case for a new PC Board then it is recomented to have a new probe also.
Posted on Sep 14, 2010
My Kitchenaid Oven doesn't allow me to set a temperature higher that 350 degrees. Electric oven. For example, i will punch in 425 and the panel will default back the temperature to 350.
350 will be the design max for your oven unless the handbook says for your model is higher rated and is faulty
repair or replace with a higher rated temp oven
Nov 07, 2016 | KitchenAid Ovens
My kitchenaid temperature probe won't turn off
If you mean the probe icon will not leave the display, you need to be sure the probe jack is not coated with food residue that is grounding it, if it is clean- send the control in for rebuild. Help Me Find My Model Number RepairClinic com
Feb 24, 2015 | KitchenAid Ovens
Digital display is higher than actual temperature on oven
there is a thermal probe in the oven to the dispay controler it is a comm.problem on this unit,replace it and it should be fine,
Mar 17, 2014 | GE JTP48 Electric Double Oven
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
56 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
