Question about Conair Weight Scale "Thinner" with Body Fat, Hydration, Bone Mass
Scale shows L only (no number or battery on rear of this inexpensive Thinner)
4 Suggested Answers
SOURCE: Problem changing battery for Conair Thinner Scale TH300
My scale is an older model, "can't locate model# in or outside" sticker on back plate is RH697. Scale was purposely setup so that no one can change the battery but a tech. Back plate had no instruct as to where battery is and the 4 small phillips screws were covered with rubber filler. I scraped off the rubber filler and opened it up, inside was a computer board which I took out (6 tiny phillip screws) to get to the battery (it was the expected 3V) the battery was front and back soldered in. That was enough for me, this company is nothing but a bandit forcing you to a tech (est. cost 45-60$) or to make another purchase. True piracy, I'm throwing it out. Make sure when buying anything that runs on batteries that the product offers ease of replacement, I am disgusted with Thinner.
Posted on Oct 10, 2010
r321567499
  • 74 Answers
SOURCE: battery cover
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
SOURCE: Conair thinner scale model TH402 displaying incorrect weight?
Conair TH402 displayes incorrect weight
Posted on Nov 15, 2010
I have a Thinner glass/brass round bathroom scale and I cannot find the battery location. I purchased this about 10 years ago from Frontgate but they couldn't help me. Can you?
I have a 10 year old Thinner bathroom scales also. Apparently the manufacturer designed it to make battery replacement hard so you'd buy a new scales. To replace the battery, if your unit is similar to mine, turn it over, remove all the screws and separate the top and bottom. You'll see the glass window that shows the weight. It is held in place by four tabs that are slightly twisted. Straighten them, lift the glass assembly clear without straining the wires, and turn it over to reveal the round black battery case. It is secured by three small screws and clear epoxy. Remove the epoxy with a knife blade, remove the screws, and separate the two halves of the case on one side being careful not to separate the other side where there is a metal connection piece. Using the knife tip, remove the CR2032 battery and replace it with a new one (available at Radio Shack or similar stores). Reassemble in reverse order; no need to replace epoxy. My scales worked fine after that.
Jan 09, 2011 | Conair WW81 Weight Watchers Body...
The scale displays 8888 every time you stand on it. If you go to choose p1 it flashes data. Can seem to get the scale to reset using the instructions and removing batteries does nothing
I have a "Thinner" scale. You have to put a little weight on it to activate, it will show 8888. Don't step on, wait a few seconds and it will change to 0000, then step on.
Jan 05, 2011 | Conair WW81 Weight Watchers Body...
Keeps showing err. Thinner scale
Tap the scale twice with your foot so 0.0 appears first, then weigh yourself. If you step on the scale before 0.0 appears, the scale will not function properly.
Sep 26, 2010 | Conair Thinner Scale by TH304 Glass Body...
Instead of showing my weight in pounds (168.00), the window is showing a different kind of number (75.). I don't know how that happened. What should I do to correct this.
Your scale is showing you your weight in kilograms what you need to do is change the settings so it shows you your weight in pounds or stones
Sep 19, 2010 | Conair Weight Scale "Thinner" with Body...
Fluctuating weight on Digital Scale from one minute to the next..
i believe that, like most electronic scales, the first time you get on the scale you must step off to allow it to zero itself. Then step back on to get your correct weight.
Jul 28, 2009 | Conair Thinner Scale by TH304 Glass Body...
Battery cover
Nov 18, 2008 | Conair Thinner Scale by TH208 Body Fat...
Conair Weight Scale "Thinner" with Body Fat, Hydration, Bone Mass Logo
266 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
