Question about Sony Televison & Video
My remote is not working on this telly but is on another one
    Scholar:
  • 120 Answers
Assuming the 2 TV's are the same model, and you are the same distance and angle from each well testing, also your battery's are good.
It would mean the IR (infrared) receiver module in the TV is bad.
Cheap fix if you take the TV some where to be fixed. If you know someone who is comfortable taking the TV apart, you get the module cheap online (under $10) and would be simple to replace.
Posted on Sep 14, 2010
I turn on tv. There is sound but no video.
hi, if you have a device plugged into the telly that gives you the picture such as sky or cable then the best thing to do is disconnect this device from the back of your telly then switch the telly and this device off at the mains, then re-fit all the cables making sure they are connected properly then switch it all on.
now check if you have sound also make sure the tells is on the correct input for that decice and also make sure the mute button has not been pressed on the telly remote or on the remote of the device you use to watch telly, if after doing all that it still dont work then the chances are something has blown on the amp in the telly.
make sure you double check all the leads going into the telly to rule out a faulty lead causing you the problems
Jul 13, 2010 | Televison & Video
Video input
Hi the only slight chancer you have of doing this without the remote and this will only work with some tellys is to have the telly switched on then the device you have connected to the video input have this switched off at the wall then with the telly on switch the device on your trying to get the telly to pick up now some tellys will pick up the signal and go to that input channel, if how ever this dont work your going to need to go out and buy an all in 1 remote, these remotes cost next to nothing to buy you can get them off the well known auction site or from your nearest cheap shop such as discount stores that sell goods for next to nothing these remotes will work on all tellys and would solve your problem if the way i told you dont work.
Im sorry their is no easy way to get it to change but without the remote your pretty much stuck unless on the telly you have a button that looks like a square with an arrow running from left to right if you have this button then pressing this wil change the input source for you, if you dont have this then the only option would be an all 4 1 remote.
let me know how you get on or if you need further assistance ok
May 31, 2010 | RCA TruFlat 27F520T 27" TV
I need a list of codes to reprogram a universal remote for magnavox televisions.
hi, please could you let me know the make and model number of your remote, this may be written under where the battery goes as each model will have a different setup option.
if you do have the manual but dont have the codes then what you can do is an auto scan where you keep pressing the standby button until the telly turns off you then save it at that point then the remote should work the telly, if you dont have manual then let me know ok
i need to know if its made by ge or rct etc as their are a few people who make them
CLICK HERE
you may find the manual or codes here
here is the guide for an rca universal remote follow these instructions to scan through all the codes on the remote and save it when you come to the correct one, this is for rca how ever their are many other universal remotes so this may or may not work
1 turn on the target device, in your case this will be the telly
2 press and hold code search until the led lights light up
3 release the code search button
4 press and release the component button you wish to program in your case this will be tv it should flash then light back up and remain lit
5 press and hold the code search button until your tv tuns off then let go and press enter to save the code.
now if your remote is and rca one then keep doing this until the telly turns off then press enter and you should then be able to control the telly with the remote, if how ever this is not the instructions for your remote then let me know what make the remote is ok.
May 26, 2010 | Televison & Video
We have the Samsung LE32A457C1DXXU and the remote has stopped working but when I press the buttons it still flashes that it is working on the actual tele. Also the a menu comes up and stays on the screen...
hi, to me it sounds like it could be one of two things the first thing i would do is take the control apart and check for water damage spilt drinks or babys dribble can cause buttons to act as if they were stuck.
So remove the case and clean the pads behind the buttons and clean the contacts on the circuit board with dry cloth, then put it back together and give it a try.
you may find doing that will solve your problem.
If not then the chances are the remote has a fault with it causing it to not operate your telly you know the remote is giving off a signal as its showing up on the telly so it may have been dropped causing a fault with the remote.
what you could try if this is the case is go out and buy one of those all in one remotes these can be brought from next to nothing and buying one of these would tell you if the telly is at fault or the remote as if the new remote works the telly then you know the problem is with the old remote if it dont work then their is a fault with the firmware on the telly if this is the case then it would need taking in a getting repaired as this isnt something you can do yourself..
Let me know how you get on or if you need further assistance ok
Jan 13, 2010 | Samsung LN32A330 32 in. LCD TV
Bought urc-7515 code 0037 for bush telly only turns off telly does not change channell or work volume
The original remote for a Bush uses several codes for various buttons! I doubt that many of the universal remotes would have the sohistication to do this. Does your remote provide a 'Learning mode? If so this is the only way to get it to work close to its original.
Aug 20, 2009 | Televison & Video
Remote Codes for Commtel Control Freak and JVC
0053, 1253, 1923 if those don't work, I have others.
Jan 18, 2009 | JVC RM-C18G-1H Remote Control
The telly in question is a technika tv lcd26 hdready tesco brought remote no good
took telly back and remote did not think it was still in warrenty 12 months just a week left tescos very good got new telly and remote thank you anyway
Apr 28, 2008 | Televison & Video
I cannot get my universal remote to work!!! we have tried everything and it will change the channel once and then it doesnt work. i have tried all the combo codes and im getting really mad!!!!!!!!!!!
Hi have you tried manually searching for the frequency like it says in manual untill it turns the telly off then store this frequency in the control if this still dont solve your problem then the remote is faulty because if your telly is listed in the code sheet then it will work on the telly if not then the control is faulty so take it back and get a replacement ok.
What make and model is your remote?
What make and model is telly?
let me know then ill look for you ok
Apr 22, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
