Question about Precor C954i Experience Treadmill
We are getting an error message 29 on the Precor treadmill. Has anyone had the some problem & what did you do to corrrect the problem
We have erorr 22,42,26
Posted on May 02, 2011
I recently bought a used Precor 954i it worked fine then when i brought it home and wired it in with a 20amp breaker and 240 volt im getting error 29 as soon as i turn the machine on any ideas?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29 Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Sep 22, 2015 | Precor 954i Experience Series Treadmill...
Precor error code 29
2. Bad lower PCA.
Corrective Action
May 02, 2014 | Life Fitness T3 Treadmill with Advanced...
Why is my Precor Efx 546i elliptical showing an error message?
2. Bad lower PCA.
Corrective Action
Feb 11, 2014 | Exercise & Fitness
Precor treadmill code e3 is on
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Precor error code 1
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
How do I fix an ERR70 message on the display of my 9.21 treadmill.
Precor Error 70, LPCA Not Read Probable Cause Incorrect or missing software in the LPCA
Corrective Action Test with a known good LPCA Precor Error 70 LPCA Not Read AMT12 Only
Jan 05, 2013 | Precor 9.21 Treadmill
Error 29 message coming up on screen
see the error code and fix it. God bless you
Error 29, Excessive AC Input Current, this mean that some elements inside of the treadmills is consuming more AC currente, like transformer, main motor.
see the block diagram attached.
Nov 28, 2012 | Precor 954i Treadmill Refurbished. 115...
What does error 29 mean on a precor C954i?
2. Bad lower PCA.
Corrective Action
Apr 06, 2011 | Precor C954i Commercial Treadmill
What is error 29
2. Bad lower PCA.
Corrective Action
Mar 27, 2011 | Precor 923 LowImpact Treadmill
Precor C954i Experience Treadmill Logo
281 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
