Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
How to I instal the ink and I am having a hard time to close the lid
    Scholar:
  • 75 Answers
Be sure the cartridge is fully inserted. You will hear it click into place when it is properly seated. Then the door will close.
Posted on Jun 09, 2008
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
I need to know where the ink cartridge goes on my x6575 what cartridge goes where
1.Turn on the printer.
2. Open the printer by grasping the printer's top lid, to the left of the control panel and just below the scanner cover ,( approx. 1 inch ) to expose the ink cartridges.
3.Press down on the cartridge carrier levers.
4.Remove the tape from the black print cartridge, insert it in the left cartridge carrier and close the lid.
5. Remove the tape from the color print cartridge, insert it in the right cartridge carrier and close the lid.
6. Close the printer.
Your ink cartridges are installed.
Feb 17, 2011 | Lexmark X6575 All-In-One InkJet Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
How to instal a new printer ink cartridge
Lift the printer unit, and position the scanner support between the tabs to hold it open.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
Replace ink cartridges
1 - Open the top lid 2 - Open the ink cartridge carrier 3 - Shake the ink cartridges 4 - Unpack the ink cartridges 5 - Remove the yellow tape from each cartridge as you get ready to install it, but not before 6 - Install each color cartridge into its corresponding color slot pressing down all the way until it "clicks" 7 - Close the ink cartridge carrier 8 - Close the top lid
At this point the printer should charge its ink cartridges. Let this finish before using your printer.
Hope this helps!
Feb 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have a Lexmark X125 printer. I just bought new ink cartridges because I ran out of ink. I followed the directions on the printer to install the ink cartridges and the printer keeps flashing the words...
Remove the cartridges and close the lid. Allow the system to try to calibrate and complain. Open the lid. Check the cartridge bottoms to make sure you removed the plastic cover on the jet heads.
Replace the cartridges and make sure they clip. Close the lid to finish.
if this does not solve it. Remove the cartridges and then unplug the unit from the power. hold the power button down for 10 seconds then give 20 seconds more. this will clear all power. Place the new cartridges in and close the lid. power the unit on and test for success
Feb 14, 2010 | Computers & Internet
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Show me how to install new ink cartridge onv305
hi eileenoreill,
you can try these steps:
  2. Lift the scanner base unit.
  3. Press down on the ink cartridge lever to raise each ink cartridge lid.
  4. Remove the old ink cartridge.
  5. Store the cartridge in an airtight container, such as the storage unit you received with your photo cartridge, or dispose it appropriately.
  6. Remove the sticker and transparent tape from the back and bottom of the new ink cartridge.
  7. Insert the new ink cartridge. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
  8. Snap each lid closed.
  9. Lower the scanner base unit until it is completely closed
  10. Snap each lid closed.
just update me if the issue is not yet resolved.
Oct 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
26 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
