Question about Olympus Cameras
Dried water droplets on inside of lens
Would really appreciate any help with my waterproof camera, the >Olympus 795SW (bought in Australia in Dec 07). After a few days at the beach (i always carefully rinsed the camera afterwards in fresh water), i saw my camera lens had spots of water on the inside! I rinsed and dried the camera again, hoping it would help....only to find more droplets when it dried off. Now, whenever i take a photos, the droplets appear in each one, rendering it almost uesless! This is not the best news, since i am currenlty on a world holiday and dont have time to send it to an authorised repair service centre. I would really appreciate any advice on this problem.
    Genius:
  • 1,689 Answers
The camera lens will have to come completely apart, and all the pieces be cleaned. This is not something you can do yourself at home. Because there is water in the lens, there is the risk that the humidity will cause corrision of some of the pieces and electronics inside of the lens unit.
You an try leaving the camera in a dry warm place that is not more than about 100 deg F for a few days to see if the water will dry out. But, I am sure that there will be water stains inside on the lens surfaces.
Jerry G.
Posted on May 16, 2008
My Olympus 1050 SW looks like it might have a little water inside the camera. The lens is foggy. I didn't take it very deep the last time I was in the water with it, but I did store it in a cooler and...
You can TRY and dry out the camera, but I can pretty much guarantee you that there is corrosion inside and it will eventually fail if it hasn't done so already. The Olympus Stylus Tough cameras are not very tough or waterproof unfortunately. I have seen dozens of them with smashed LCD windows or that have leaked water.
Don't buy a waterproof camera, cause they aren't waterproof. Buy an underwater case and put your camera in that.
To try and dry out the camera, some people suggest putting it in a ziplock back with rice to pull out the moisture, it's not a bad thing to try. The fog in the lens MIGHT go away, but it will most likely leave spots or a big ring which will show up on all your pictures.
Your camera is most likely a goner, sorry to say.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Olympus Stylus / mju 1050 SW Digital...
My olympus stylus 6020 is about 5 months old. while trying it out in fresh water, the camera worked initially and then after a couple of pictures turned off and a "reformat memory card' msg came...
Once a week, I climb a mountain and shout for all the world to hear...."the only truly waterproof camera is one in a specially-designed plastic waterproof housing. Any point and shoot camera that says it's waterproof WILL LEAK! You just don't know when."
May 03, 2011 | Olympus Stylus Tough 6020 / mju Tough6020...
The lens cover won't close or open all the way.
Got It! You might try just soaking the camera for a little while like one response said. But I just removed the front face plate. There was accumulated gunk holding the lens cover, and I had the exact same symptoms you're describing. Gently wiped it all clean and presto! all good. You are not opening the camera, just removing the front face. There are three small allen screws on the front and a small phillips screw on the edge.You will need a very small (1.5mm) metric allen wrench (found in common allen wrench sets), and a very small screwdriver for a little screw on the side (found in common micro screwdriver sets). Keep track of which hole each allen set screw came from, they are all different, in fact one appears to be just decoration and has no threads, I just secured it with a tiny dab of all purpose adhesive (Ace hardware brand). Check the tab near the lens goes back in place. Dr. John Christensen
Jun 29, 2009 | Olympus Stylus 720 SW Digital Camera
Drowned waterproof camera !!??
I would take batteries out open camera the best you can and let it dry out for a week at least!! then replace battery and try again,Most times when it is fully dry the camera will start to work again! ! If that does not work I would contact the company! and even if the warranty is up they may still fix the problem for free or low cost!
Jan 04, 2009 | Olympus Cameras
I just posted this answer on an old Dec. 07 posting.
In case you can't find it, try opening the DC IN / USB port cover just to the right of the dial. This breaks the waterproof seal and allows the camera to open. I think the design flaw is an inadequate volume differential in the water sealed cavity to properly account for the change in volume caused by the lens opening / retracting. The USB cover can be closed once the lens is open to restore the waterproof characteristics.
Mar 24, 2008 | Olympus Stylus 710 Digital Camera
Date Imprint
Throw the cam and buy a good one, this camera was bought by me to record the site photographs but with out a date imprint on them they are not even worth a tissue paper.
Feb 28, 2008 | Olympus Stylus 770 SW Digital Camera
Weatherproof
The Stylus Verve weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus Verve is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Weatherproof
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Weatherproof
The Stylus 500 weatherproofing protection is equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus 500 is designed to operate at ambient temperatures of 32?-104?F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and cannot be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Weatherproof
The Olympus Stylus 300/400 Digital is the first metal-bodied digital camera in the world to feature protection equivalent to IEC Standard publication 529 IPX4. The camera will not be damaged by water splashed from any direction. The camera can be used outside in adverse weather conditions. If you are taking pictures when the camera is exposed to rain or snow, make sure that the optical components (lens, viewfinder, flash) are not covered with water. Water droplets on the lens may affect image quality. The Stylus 300/400 Digital is designed to operate at ambient temperature 32°-104°F and relative humidity 30-90%. Please note that the camera is weatherproof, not waterproof, and can not be immersed in water. Olympus will not assume any responsibility for any camera damage caused by water getting inside as a result of misuse by the user.
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
Cameras Logo
214 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
