Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
I have a poulan 25cc trimmer (P1500). It's about a year old. Recently, after trimming for 15 or 20 minutes, it tries to stall out... eventually it dies and will restart and run briefly then dies again. Any ideas?
  • 2 more comments
  • mclark13 Sep 16, 2010
    The filter is clean but I just discovered that one of the fuel lines ends at the top of the fuel tank. The other goes to the bottom and ends with a filter. Is this normal or should both lines go all the way down?
    No, there is definitely oil in the gas but I just finished of my oil/gas mixture. I think I will empty out my tank and make a new batch.
    It starts but now it will just run a short while and will try to die. If I work the throttle up and down it tries to run but eventually dies. It will restart but won't run for long.
    Did you get my message regarding the part I found in the fuel tank? It wasn't posted on the web site.
    Problem Solver:
  • 3 Answers
When I poured out the old gas a small part came out of the fuel tank. It looks like it would fit in the end of a fuel line. It's green, about 1/2" long with what looks like a black star washer on one end. It has a hole through the center with a flexible tip on one end. I can email you a photo if you can give me an email address.
Posted on Sep 16, 2010
    Problem Solver:
  • 3 Answers
I'll try the new mix but I don't think it would start with a fouled plug. I starts relatively easily.
    Problem Solver:
  • 3 Answers
It starts but tries to die. If I throttle up and down it tries to run but eventually dies. It will restart but won't keep running.
  • 2,299 Answers
You can check a few things. Either the air filter is plugged up and the carb isn't getting enough air. Or you got a small piece of debris in the carb. Sometimes if it is debris stuck in the carb then you can just keep starting it over and over again and the debris will dislodge itself.
Posted on Sep 15, 2010
  • 5 more comments
  • Rodney Clark
    Rodney Clark Sep 16, 2010
    Yes this is normal. Does the trimmer start and run ok when it is cold still? For an example, can you go start the trimmer now and it will start and run for 15-20 minutes? If it will then it is overheating. Check your fuel, oil mixture. I know that I have done it, filled the weed eater gas can up with gas and didn't add the oil. That will for sure cause this problem.
  • Rodney Clark
    The line at the top of the tank is a vent line.
  • Rodney Clark
    So does it start and run now? When it is cool? Or did it die the last time you were using it and still will not start?
  • Rodney Clark
    It could also be a fouled spark plug. I would put new mix in it and try that. If that doesn't work then the next thing I would do is change the spark plug.
White smoke from p1500 trimmer
Too much oil in the gas or water in the gas
Drain the gas, refill with fresh clean oil/gas mixture
Apr 03, 2016 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan p1500 carburetor kit
If you need to get areplacement part, check the following site
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
Jul 07, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan p1500 starts and runs fine until I try to trim the grass, then it dies. What is the problem and how can I fix it.
Rick it sounds like too much fuel is getting through. Clean the air filter first and then try adjusting the jet screws beside the throttle cable near the carb.
Aug 17, 2013 | Poulan "P1500 16"" 25cc Trimmer"
Type of trimmer: Poulan Pro PP125 17-Inch 25cc 2-Cycle Gas-Powered Straight-Shaft String Have not used the trimmer in a couple years due to broken fuel line. replaced the lines today. The primer bulb...
Try cleaning your carb and even buying a rebuild kit. I do not think you have a blockage. Does it even try to start? Cleaning the carb will give you a chance to get rid of any debris or old gummed up fuel and oil that may be in there, give it a try. Good Luck...
Jun 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
My sst25 starts hard and stalls...seems to be sensitive to engine position before stalling...stalls when throttle is opened and when just runnung
Had the same problem with my SST25 and after looking further, noticed something rattling around in the fuel tank. The fuel filter had fallen off of the small fuel line (actually the small fuel line had broken). Removed filter from tank and small piece of broken line from filter connector, and re-connected to small fuel line.
Jul 11, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Where can i buy a fuel line and coupling for my craftsman gas edger
Getting them from Sears.com is probably the easiest. But any mower shop has access to them.Most sears edgers are made by Poulan
Nov 21, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
166 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
